L-98 Engine Question?
Discussion in 'The Garage' started by 68 Suburban, Aug 15, 2002.
  1. 68 Suburban
    68 Suburban Registered Member
    Apr 9, 2002
    42
    Phoenix, AZ
    Does the L-98 Corvette engine found in 85-91 Corvettes and Camaros have the ability to be run with a mechanical fuel pump?
  2. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Not with the Tuned Port Injection still intact. The TPI setup requires much more fuel pressure than a mechanical pump could ever supply.
    Mike
  3. 68 Suburban
    Apr 9, 2002
    42
    Phoenix, AZ
    Thanks for the response. I am just interested in the block and not the fuel injection. The engine would be carburated.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My L-98 block got ventilated long ago, so I can't look for ya. /forums/images/icons/shocked.gif However, adding an electric pump that's carb compatible wouldn't be difficult. /forums/images/icons/cool.gif
    The stock cam in the L-98 is tuned to work best with the TPI, but even then those engines were only rated at around 245 HP. A different cam would certainly perk it up, but it takes a roller cam so expect a replacement cam to cost $300+. /forums/images/icons/shocked.gif You can reuse the stock roller lifters as long as they're in good condition. If the engine is really from a 'vette, it will have aluminum heads. I'm pretty sure that they used iron heads on the L-98's in the Camaro/Firebirds.
  5. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    They do have the mechanical fuel pump provisions that will work fine with a carb.
    Mike
