lack of oil to valvetrain/rockers? *DELETED*
Discussion in '1982-Present GM Diesel' started by jp0863, Aug 15, 2004.
  1. jp0863
    jp0863 1/2 ton status Premium Member
    Aug 15, 2004
    566
    clovis, ca
    Post deleted by jp0863
  2. jp0863
    Aug 15, 2004
    566
    clovis, ca
    Re: lack of oil to valvetrain/rockers?
    ok, for those who are interested i think i may have solved my problem. while the valve covers were off i liberally doused the valve train w/fresh oil, then fired it up. i reved the motor for a few minutes to build up pressure and out came the crap and some fresher oil. so i may have fixed my own problem by meerely reving the motor. not alot of oil came out, but enough to provide oil to the rockers and valves. so now begins the process of putting it back together.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you have to rev it that high to get the oil up then you might have had a bad oil pump that starved the engine, ruined your bearings and now even with a new pump the clearance on the bearings is high and you will wstill have low oil pressures.
    /forums/images/graemlins/dunno.gif
  4. jp0863
    Aug 15, 2004
    566
    clovis, ca
    just put the oil pump in two days ago. i appearently had some crap in the oil galleys or oil cooler(not sure if it goes through the cooler first), but all seems fine now. good oil flow at idle. it sat on a military base for quite some time collecting dust. i'm sure the engine needs going through, but ill drive it til it breaks and then have it rebuilt or swap to gas. it's not by any means a daily driver so i'm not too concerned.
