lacks power
Discussion in 'The Garage' started by johnathan, May 21, 2006.
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    My dad bought a 78 chevy 350/350trans.The motor seems to run great,it just lacks power.What are some things to check besides comp.test and vac test and timing exhaust seems to be clear too,no cat
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    how many miles? If it really seems to lack power then its not running great is it? If its really running great, its likely just tired or you are expecting way too much. A stock 78 pickup wouldn't have had a ton of balls. What gear ratio in the axles? Could be like my 84 K5 and have 2.73s behind a 305. Yeah that was a good choice...
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I think the 350 SBC truck engines were only rated at ~160 HP or thereabouts in 1978. The pre-EFI smog years were a terrible time for car and truck enthusiasts.
    Thankfully, there are easy-in crate engines :D
  4. TDAWG1
    TDAWG1 1/2 ton status Premium Member
    Jan 18, 2005
    2,836
    8
    Grand Junction, Crawlorado
    valve seals
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Yeah I would'nt expect it to be hot rod,but compared to the 350 in my K5 it just seamed mighty sluggish
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yours is an '84. 1978/79 was a dismal time for smogger engines. :( The main "solution" from Detroit seemed to be lowering the compression until the engine barely ran. :mad: Compression ratios in the 7.5-8.0:1 range weren't uncommon then. :( I had a new '79 F-150 back then with a 351 and it could barely get out of its own way. :doah:
  7. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    try a full tune up, fuel filter, plug wires, the works. also run some Sea-foam through the tank and get fresh gas in there, sometimes this makes a big differance in an older truck that may have done some setting. Just my .02.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    really !!!! I used to wheel the hell out of mine.. always had enough power.....
    had 33's and 3.73's with a turbo 400.. then came the 33's and 4.56's with a manual (full rollin chassis swap!!!) :bow:
