Lame Engine
Discussion in 'The Garage' started by TSGB, Nov 30, 2004.
  1. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Alright, from what I read around here, I've narrowed it down to a vacuum leak, or a distributor problem. How can I check for vacuum leaks? And how can I inspect my distributor (if possible) to find out if that's causing the problem? I've heard you can get a nasty dose of electricity from them, and I don't want to find out the hard way.
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You can get a nasty shock from HEI, I have. /forums/images/graemlins/tongue.gif Only when it's running though.
  3. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    I use carb cleaner to find vacuum leaks--use the "straw" to guide the spray at any suspected hoses,gaskets,and listen for a change in RPM's with it running--usually it will want to stall if the cleaner gets sucked in through a leak.Some folks use an unlit propane torch with a hose over the burner to direct the propane to the desired spot,I tried it a few times,and after I set my beard on fire when it went "whooof" when I found a bad plug wire--I went back to carb cleaner!!. /forums/images/graemlins/blush.gif Dont spray the distibutor,either by accident or on purpose--I've seen the caps blow off in a thousand peices-- /forums/images/graemlins/shocked.gif /forums/images/graemlins/yikes.gif
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hell ya thats hurst like hell, made my arm go numb from the elbow down, no fun at all /forums/images/graemlins/yikes.gif
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Thanks for the tips guys!
  6. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Look for carbon tracings on the inside of the cap and the general appearance of the rotor and the nine contacts in the cap and I'm sure someone will help ya out with some other ideas.
