Lame Question -- Getting a new radiator -- Need Opinions
Discussion in 'The Garage' started by Lance, Mar 12, 2003.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    It's a lame question I know but I searched and didn't find exactly what I needed. I am looking for opinions on what would be the best set-up for my Jimmy.
    Some background on my situation, I am replacing my stock tranny (either BTO or TCI haven't decided which) in the next few weeks and I will be adding a lock-up torque converter and a tranny cooler at the same time. I want to replace my radiator at this time.
    My future plans include a slightly over-bored TBI 350 w/ vortec heads and a mild cam for it (I just starting tearing down my new block). I live in Alabama so heat is definitely an issue and this truck is sort of a daily driver. So what's everyone's opinions and experiences? 2,3,4 row radiator, aluminum, etc. Too many options out there and I want to pick the best I can afford.
    Thanks for the advice,
    Lance
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'm running a 4 row w/ a 180 degree t-stat, and it runs cool. Also have the stock clutch fan.
    John
  3. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Lance,
    Before you buy one let me know. I think I can save you a lot of money!
    Mike
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I just bought a stock replacement ( 4 core, copper)radiator. The only thing I have to say is if you are having overheating problems is. Take the tranny cooler out of the radiator and put an external tranny cooler on it but not in front of the radiator. I had over heating problems with my K5 I when through and replaced the water pump,radiator, elec. fans. and then moved the cooler and the problem is gone.
  5. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Sent ya a PM! /forums/images/graemlins/smile.gif
  6. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks for the tip, that's definitely my game plan. I've had similar issues before.
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    My K-10 has a be-cool aliminum raditor with a 16" electric fan and my tranny cooler has a fan on it also It's available in summit both items work great I have a Tci 700r-4 and I love it but I've been reading about those Bow tie overdrive trannys and I think it might be a better deal Good luck /forums/images/graemlins/truck.gif
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I agree with Todd, get a manual Tranny Radiator and just run a external tranny cooler, and don't go with a 2 core, stay with the 3 or 4.
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Whether you go with a radiator with internal cooler (for tranny) or not, get a 4 core. They aren't much more than a 3 core. You will have to get new "cushions" (the rubber mounts that the radiator sits in), but those can be had for fairly cheap through LMC and others. I found going this route that even with the internal tranny cooler, my temps are perfect (my truck originally came with a 3 core and internal cooler). It ran warm until I replaced the radiator. My radiator was pretty scaly and old, so that may have been the biggest problem or maybe even only problem (old radiators with built up scale DO NOT transfer heat as well).
  10. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Put a 4 row in my 91 1500/350 sub and it rarely, if ever get's up over 1/2 way now even while towing in the 'blistering'? Wisconsin summers! /forums/images/graemlins/smile.gif Ran about $130/delivered with life-time warr from radiators.com Click me! Also added aux cooler after that, but didn't notice tranny temp being an issue. There were some small mod's to the rad mounts to go from 3 to 4 row.. (new rubbers, a tweak here, a tweak there), but not rocket science. /forums/images/graemlins/burb.gif
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I always go bigger with the radiator. I usely tell the radiator shops I need a heavy duty radiator for a built up 454 even though I'm only running a small block.
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought a 3 row radiator from AutoZone 4 yrs ago for $99 lifetime. It works like a dream. I live in Tucson Az and it's hotter than all hell here in summer. I run a 190 thrmostat. I was told a bigger radiator holds more hot water. I've never understood the tank, capacity, thermostat equation but since I replaced my motor last July my motor has never gone over 190 even during the break-in with the A/C on
  13. Lance
    Mar 4, 2002
    606
    Birmingham, Alabama
    Thanks for the input everyone, new question, same subject. Are the Griffins, Be Cools, Howes, etc. radiators worth the extra coin and can anybody give me the breakdown of benefits of aluminum over copper radiators.
  14. yellowK20
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    I had a stock 4-core In my stepside that was in good shape But I got a deal on the aluminum radiator that being said If a had to buy a new raditor I'd spend the extra money and get another aluminum one There was probaly a 25 degree differance between the stock 4-core and the 2-core aluminum If you can afford it go aluminum plus the aluminum raditor is way lighter /forums/images/graemlins/truck.gif
  15. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I replaced mine last year, it came factory with a 3 row, but I bought a Modine 4 row which is a factory replacement for a 454 truck. I put a 160-deg thermostat in it and it rarely gets up to 170 degrees. I love it. I was tired of it running hot on me. /forums/images/graemlins/thumb.gif But you also have to consider that I have a 400 small block and not a 350.
  16. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Use your CK5 discount at radiator.com (10% off) and a new 4 core is something like $162 delivered to your door (FED EX overnight delivery too I think it was...).
  17. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Yep it is overnight. That is where I got my radiator from. It works great.
