Larger front wheel studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Feb 26, 2003.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Anybody converted from 9/16" to 1/2" front wheel studs? I want the same size studs in the front and rear.
    BTW its for a semi-stock 6 Lug 10 bolt.
  2. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    no but i have gone from 7/16 to 1/2. why do you want to go down just make the other 9/16
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Even tho hes a Schmuck /forums/images/graemlins/wink.gif, I have to agree w/ him. I would convert the front to 9/16 if anything.
    But I am pretty sure you can get shouldered studs to neck it down.
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    What kind of rear are you trying to match? /forums/images/graemlins/confused.gif
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    He just got his numbers confused. He did say it's a 1/2 ton so from 7/16" to 1/2"
    I have done this and now I don't break lugs off.
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Where did you get the studs to go to 1/2" for the front?
    Dan /forums/images/graemlins/burb.gif
  7. zcarczar
    Feb 10, 2002
    2,495
    Thanks Iceman, I did get my numbers confused. Im curious did you have to drill the holes out where the wheel studs mount to get the new larger studs to fit correctly?
    Im trying to match the 1/2-20 wheel studs that are in the rear axle. I have the stock crap in the front and they are just way to small for my liking.
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You do have to drill.
    As for where I got them from, it was a parts store in europe and we basically took one of my lugs off and matched it with a 1/2" with the same length.
    I believe it ended up being a front from a 2wd five lug.
    I will try and make sure and get you #'s, since I will be doing it to my new axle.
  9. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    How about 70's F100/150/Bronco? They use 1/2 studs and a very similar hub and rotor. Dunno if you need to drill the hubs out bigger... IIRC, the shanks on the 7/16" studs are larger than the threaded portion.
