Larger lift for 1 ton
Discussion in 'The Garage' started by 53chevy, Sep 22, 2006.
  1. 53chevy
    53chevy 1/2 ton status Premium Member
    Dec 29, 2004
    369
    7
    pitcairn
    I am looking into a lager lift for my 4 door long bed chevy. I have the standard 6 inch lift for a one ton i just can't find a place that makes one larger. In the rear i'm planning on a shackle flip but what can i do in the front to raise it. I would like all spring lift but for the spring size its hard to find. Can i get the spirngs custom made for a fair price. I have a winch and bumper on front and planning a cummings turbo diesel so i'll need a little heavier rates. Thanks
  2. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    lifts for 1/2 and 3/4 tons will be the same for 1 tons. the only difference will be the rear springs cause 1 tons and some 3/4 tons have 56" springs and 1/2 and some 3/4 tons have 52" rear springs. most of the time companies will want you to specify the rear spring length. as far as fronts go, they are all the same and the large lift springs will most always have high spring rates so you should have no problem with your heavy front end and if it doesnt sit level you can always add a zero rate in the front.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    bds makes 8" springs, tuff country makes 8", superlift makes 8,10,12" skyjacker makes 8"
    thats the order i would buy them in
  4. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    I thought the 1ton springs are different for the 1/2 and the 3/4 ton springs?
  5. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    thanks for the info
  6. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    With respect to off the shelf lift kits, the front springs are all the same.
  7. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    how much should 2 pair of 12inch of superlift spring cost? i found thhttp://cgi.ebay.com/ebaymotors/73-91-Chevy-10-Lift-Springs-Pickup-Blazer-Suburban_W0QQcmdZViewItemQQcategoryZ33585QQihZ013QQitemZ230031979932QQrdZ1ese
  8. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
  9. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
  10. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    well now with the 54" bogger soon how much lift am i going to need 15" and fender triming, who sells 15" packs? and are there any good spring websites.
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    No one sells 15" packs in the aftermarket world off the shelf except for the custom spring manufacturers such as Deaver, National, etc.
    I have some 12" Superlift front springs and 8" rears which will fit your 1 ton with modification to the rear spring hangers. Shoot me a PM and we can talk.
  12. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    how about these!!!
    a full 20 inches!!LOL
  13. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    get yourself some 12" front springs w/ 5" drop hangers and a 3" BL. That should get you crawling the mall quite well, 20" worth that is. For the rear you'd need a 4" Shackle flip, the 3" BL, and then finish it off with either 13" custom springs or 10" Springs and a 3" Block.
  14. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    there is no way that truck has 20" lift. When I had my show truck I had 15" total lift(springs/hangers) and I had plenty of room for 44" boggers and 46s would fit with a lil rubbing and if I would have put my 3" BL back in I could have got 49s.
  15. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    he has a huge bumper!!!! its still awsome
  16. Jackedup86GMC
    Jackedup86GMC Registered Member
    Jul 27, 2006
    64
    Southeast Texas
    So how much lift would be required for the new 54" Boggers? These new tires bring up other issues as well. Like would a 60/14 axle combo even hold up to them in real wheeling conditions? AKA not mall crawling! I can remember a time when I thought 44" TSL's were huge. Does anyone else remember those days?
  17. TeK
    TeK 1/2 ton status
    Jan 3, 2005
    170
    Greenwood, IN
    60/14B combo could. 40spline axles up front in the 60 or run longfields in the front with a detroit, deadenber inner cs and knuckles. the rear would probably be fine just replace with some chromo shafts.
  18. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    customsuspension.com makes pretty much anysize spring you would need. i think they go to like 24". but they are about $400 a piece, but something tells me if your bout to buy some brand new 54" boggers thats not to steep. theres a suburban on cardomain that has about 15" plus a 3" body lift. and i think you might need to go a wee bit bigger than that to fit 54's. unless you do alot of trimming. I was going to buy some springs from them but ive decided after being on ck5 for so long and never really owning a 4x4 that i would start into stages. also do you have cross over steering. you might want to look into that. scratch that they make 30" lifts!!!!!!!!!!!!!!!!!!!!!!!!
  19. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    here are some pics of extreme offroad cool trucks they make 30" lifts
  20. 53chevy
    Dec 29, 2004
    369
    7
    pitcairn
    Do you think it woul be ok to go from the 56inch rears to 52 inch rears. Seems like that would b eaiser to get a lift, but i want to wheel my truck still. Thanks for all the info and pics keep it comming.
