Larger oil filter trivia
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex, Sep 11, 2001.
  1. Alex
    Alex Registered Member
    Jun 19, 2001
    78
    Northern California
    Hi all, I know this is an old subject, but I’m just curious. I'm running an AC 1218 oil filter on my '91 full size Blazer (5.7L). The manual specifies a smaller oil filter. Anyone else using the AC 1218? Of course I prefer the larger filter but I’m not quite sure why GM would recommend a smaller filter. Also, I have the OEM oil cooler if it matters. Any thoughts?
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    To be honest (I am no oil filter expert), but I believe running a larger filter will not hurt (double check to make sure). I think some application call for a smaller filter due to space restrictions. I do not run Frams any more, but mine used to call for a PH30 and I used to run a PH13 (which was bigger with no problems). I have read that since they all are designed to work at approximately the same pressure range, that it is not a problem, but again I am no expert.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Space considerations. Also, when your engine dumps the oil into the larger filter expansion occurs and heat is released (a little physics refresher). Not much though since it is a small space. I put mine on a remote filter and run a larger filter. The headers was cooking the oil where it was located.
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    I run a 1218 thought it was bigger than a pf35 but they look to be the same size.
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Alex, I got into it with the parts clerk over this very same issue. The 4wd fiter is smaller than the 2wd filet but the sma engine. He said it was was for space/clearance.
    But I have no trouble or clearance issues with the large one.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
