Larger tire on interior rack?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Jul 19, 2000.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I was wondering if anyone had put a larger tire on the interior holder. There is room front, back, and up, but not down. I would like to mount a 33x12.5 tire in there. If there is no way to do this, how close in size should the spare be? Thanks.
    Brian
    84k5, 4"Skyjacker kit,33x12.5 goodyear mtr, and 15x10 bajas ordered!
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I have a 33x12.50 on a 15x8 rim mounted on the factory inside carrier. On mine the wheel retaining bolt has a slot with about 3-4" of up and down travel to accomodate different size tires. There is also just barely enough room between the tailgate and the rear seat for it to fit, as it rubs both the seatback and the tailgate.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Duno about the first part of your question but I would say the spare should be the same size as the other 4! running a different size would allow your differential to spin at different speeds and in my mind that = POW!! [​IMG]blown diff!!
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  4. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    i tried to put a 33" on mine, and it kept the rear seat leaning forward a little bit. i think i may have to go with one of the custom carriers on the back. i got some plans off this board awhile ago, now i have to just get the time and materials together.
    <font color=purple>delta9blazer</font color=purple>
  5. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I was looking at it and I saw that it was adjustable up and down, but I didn't know if it went far enough up for a 33. My 33s are coming in this week, so I'll try on one of those on it before I buy a spare. Thanks for the help guys.
    Brian
  6. Mint90
    Mint90 Registered Member
    Jul 9, 2000
    33
    Illinois
    Burt: Um...isn't that what a differential does on a regular basis?
    Mint '90 K5, All Stock, All Options, 49K
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I have a BFG 35x12.50-15 on a stock rim (accual size 34") in my stock spare carrier. The back seat is straight up & down, not slightly reclined like it should be, but it fits. The small round plate that should fit over the center hole no longer does, but it still gets the job done. Jim.
    BigJBear '80 GMC
    http://www.bigjbear.coloradok5.com
  8. Burt4x4
    6,854
    Mint90,
    True, just thinking if it were a drastic and constant diference in speed then things 'may' break/heat up then break. And if a tight posi or especially a locker....well you see how brain is thinking now. I just wouldn't want to be the one to test the limits of a diff. or think that running a diferent size tire is OK, I sure wouldn't recomend it for pavement driving.
  9. 89K5
    89K5 1/2 ton status
    Jun 14, 2000
    134
    Maryland, PA on Weekends
    My buddy had an 87 with a 35" in the stock holder. It took up almost all the space and he didn't see much out of his rear view mirror. I've had 35s for two years, no spare. I don't have time to 4wheel too much. Once I need a new set I'm planning on saving one as the spare, using the rear bumber carrier used on the Urban Assault project truck.
  10. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Got a 35 12.50 on 10in rim. Just let the air out, and carry a pump. Using stock mount.
  11. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Re: Yes it will fit
    I have a 35" x 12.5"/15" BFG All-Terrain mounted on a matching AE 589 15x10 rim that fits fine on the inerior carrier. It does take up alot of room and the seat rubs the tire some but it will fit. My seat still reclines, because I use the round washer (meant for the center hole), the bolt and wing nut in one of the bolt holes in the rim instead of the center hole in the rim. Try that...
    Mudzer 1978/91 K5
  12. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Re: Yes it will fit
    Thats a good idea Mudzer, thanks.
    Brian
