Larger washer fluid reservoir
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Predator, Jan 19, 2002.
  1. Predator
    Predator 1/2 ton status
    Jun 19, 2001
    130
    OKC,OK
    Anyone converted to a more powerful windshied washer pump & larger reservoir setup. I went scouring the yard today for a LARGE reservoir with the integral pump and didn't find anything out of the ordinary. Anyone know of any vehicles that had massive reservoirs?
    My K5 Buildup: <a target="_blank" href=http://www.geocities.com/gettin_deep>http://www.geocities.com/gettin_deep</a>
  2. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    [​IMG] just curious, but what do you need more than a gallon of wiper fluid for?
    and how powerful and large are you talking about?
    [​IMG] you could get a washdown pump for a boat, and a 5gal holding tank, and it is 12 volt and pumps 2-3 gpm at 40psi
    [​IMG] just an idea
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  3. Predator
    Jun 19, 2001
    130
    OKC,OK
    I don't want to run out during a day of playing in the mud with the washers set on "constant." [​IMG] Maybe a couple of gallons would work......
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i was thinking of having two washer pumps/reservoirs. the stovk one, and a big one. something that clears off the mudd i go through. i think ill have it squirt from inside the sunvisor that way it cant get covered in snoe either.
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Some of the older Volvos had a pretty good size resevior. I had a '70 and a '74 ( the '74 was about 2 gallons!) Them Swedes sure know how to play in the slop!
    Real trucks don't have spark plugs!
  6. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I used a washer tank &amp; pump assembly out of an older Mercedes. It holds about a gallon and a half and has a built in washer pump that I hooked up to a toggle switch. Good luck.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
