Largest 12v battery available?
Discussion in 'The Garage' started by Ned Kelly, Feb 9, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Besides the usual automotive 1000cca Optima's, Everlast, State Battery, etc., what is the largest 12v battery available? Guys have mentioned 1300cca truck batteries on some threads - I've never come across something like that. Anyone?
    I thought instead of the hassle of mounting two batteries, maybe get the biggest ONE battery (within reason of course).
  2. Uncle Fester
    Uncle Fester 1/2 ton status
    Mar 23, 2006
    229
    Cheyenne
  3. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I saw something like this at sam's club. My m1009's batt. tray is big, but not that big. I can fit 2 optima red tops on it, so they may as well be one batt.
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    8D
    Very common in the marine industry.. Unfortunately I haul and install about 50 a year.... They weigh about 100 lbs.... I ran one in the trunk of my Chevelle...
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    good traction aid in the 'velle thats for sure:D
  6. 5280k5
    5280k5 1/2 ton status
    Dec 18, 2005
    1,175
    Aurora, CO
  7. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Ryoken,
    Would those be deep cycle, or starting also?
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    They are deep cycle.. The only difference between a cranking and deep is deep cycle will have less cranking amps to make up for their huge reserve capacity... its in the plate construction, deep cycle plates being solid, thus why there are many "hybrid" batteries, really a combo of starting and deep cycle..
    most 8D's have a CCA of about 1200, but the reserve capacity are usually about 3x's that of a starting battery, usually about 550 or so... Not much of an issue with cranking power, considering they're installed to spin over monster 12 cyl Mann diesels and such....
  9. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    PC 1700T Specs:
    • 1700 cranking amps for 5 seconds
    • 1540 cranking amps for 10 seconds
    • 1355 cranking amps for 20 seconds
    • Short circuit current over 3500A
    • 68 amp hours
    • 142 minute reserve capacity with 25amp load
    • With SAE automotive terminals
    • Length 13.0"
    • Width 6.5"
    • Height 7.5" including terminals
    • Weighs 59 lbs
    Odyssey design:
    • 3 year full warranty
    • Rugged Drycell sealed design
    • Military grade
    • Vibration resistant
    • 60% more starting power
    • Deep discharge reserve power
    • 2 year storage life
    • 8-12 year design life
    • Can be mounted in any orientation
  10. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    8D.........for sure. Caterpillar uses them alot, they have they're own brand though its still size 8D. I work with them quite often on gensets and equipment.
  11. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    The 1200 cca battery I ran in my GMC was actually for our Case Tractor (400 cube I6). We replaced the batteries in it, since the one quit holding charge, so I snagged the good one. It has since suffered the same fate as the other one, and barely holds a charge anymore.
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    • There's the difference between a cranking and deep.. Nice cranking amps but 3x's less reserve...
      Personally, I run a pair of group #27 deeps.. Gives me 2200 CCA'a and about 900 mrc..... Eventually I'll go gel in the same size...
  13. mudnmyvayne
    mudnmyvayne 1/2 ton status
    Jan 13, 2004
    173
    Texas Panhandle
    I run a Optima as my primary battery & have a 8D mounted in the back to run both my winches. I havnt had dead battery issue since i installed the heavy sun of a gun.
    I have a 8000# tulsa in the rear & a warn 12k in the front. A single optima(even duals) simply could not keep up with the drain i would sometimes put on them. A 8D has solved all my winching problems.
