Largest rims & tires to stuff into a Suburban
Discussion in '1992-Present Chevy & GMC models' started by Yohinan, Jun 7, 2003.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    I was just about to ask the size question for my 95 but I just got my answer that 265's are the largest tire to stuff on stock rims. I was hoping to get some 33's but I guess that I need to get bigger rims now also. I am trying to avoid lifting my truck so can someone tell me if a 16x10 rim with 33's will fit my stock 95 burb. If it makes any difference it is a 4x4 but not lifted. Thanks John
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Some guys are getting away with 255/85R16's and no rubbing. They're a little taller that the 265/75, but narrower (the main reason they don't rub).
  3. finnd
    finnd Registered Member
    Dec 27, 2001
    65
    Northern Virginia
    on a 1500 you should be able to stuff 285/75r16's under there with only a little tweak to your torsion bars and not impact ride. on the 2500 series you should be able to get 305/70r16's in there with a little torsion action.
    I'm running 305/70r16 BFG AT's on my stock k2500 but i did upgrade to the 16x8 bling bling. ;-)
  4. Yohinan
    May 21, 2003
    103
    San Diego
    Dan,
    Any idea if a 16x10 will fit under my 1500 without a lift? or do I have to stick to the 16x8 size? Thanks again. John
  5. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    291
    Truckee, CA
    No way 16x10's will fit. On 16x8's you'll probably have to trim to fit 285's, you can only fit those on stock rims without mods. Even though 16x8's are only 1 inch wider, the backspacing is different.
