largest SBC oil filter?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, May 29, 2001.
  1. dyeager535
    26,979
    Wat is the largest (like 2 quarts?) oil filter that is avaiable commonly for the SBC? Not running headers, so no clearance issues with length, just wondering if anyone knows a NAPA or even Fram # for the big filter. I know there is one out there, and I seem to remember that it was used also on the mid 80's Coprice cars. (Option 9C1) but not positive. No way I'm actually going to USE Fram, but I can cross reference their part #'s easily.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    fram double guard, but i dont know the part number. and fram aint so bad. but it aint so good. my buddy had a K&N on his truck i think it was like 1.5 quarts. not sure though. and i have no part numbers.
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  3. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    It is a fram PH373.
    eric
    Hell, it don't really matter....it's just for my race car.
  4. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    HI Dorian, the NAPA # is 1794 that one is 2 quarts.
    p.s. Thanks checking out the Blazer for me, im way stoked now, you totally put all questions out of my mind. I will call you later tonite. TORI
    STOLEN '89 K5 - 4" lift. Found in Compton,
    stripped and dismantled.
    New Blazer on the way !!
    <A target="_blank" HREF=http://www.tori89k5.coloradok5.com>http://www.tori89k5.coloradok5.com</A>
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    you dont want to use fram but you will use napa? makes no sense. a race car without headders and oil filter relocator? what class?
  6. tori89k5
    Apr 12, 2001
    946
    Hey SEVENTY4BLAZER, Go to Dorians site and read up on his oil filter comparrison, I think you'll understand then....
  7. 1bad82k5
    May 8, 2001
    185
    MT
    I am impressed. The comparison of filters was great. I sell these things at work everyday and have always been a big fan of fram, but the test results may sway my decision. Thanks for the great comparison.
    eric
  8. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    I've seen quite a few write ups on fram and they're never good.
    Main reason; the cardboard seperator between inlet oultet fails.
    K&N thank you!
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM!
  9. dyeager535
    26,979
    If the Fram Doublegard has Teflon in it, you are doing just as much harm as good. Dupont had to be SUED to let companies use Teflon in oil additives, because Dupont testing found that Teflon is NOT suitable for use in engines.
    Dorian
  10. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    The Baldwin B7 is a 2 quart filter that works on the 6.2 diesel. I'm pretty sure the filters that fit the diesels fit the SBC. If you can't find one try look at a semi truck service center or any place that deals with fleet vehicles, they'll probly have them.
  11. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Baldwin also has a hydraulic filter that fits a SBC that's 2 qt. I don't remember the number off hand though.
    I'm not creative enough to comeup with a new signature [​IMG]
  12. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    The baldwin B7 is what i use on my truck...
    Donations accepted for the "Build Chaz's 1972 K5 fund"!!!
