Largest tires on rally wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sturzinator, Jun 12, 2001.
  1. sturzinator
    sturzinator Newbie
    Jun 12, 2001
    4
    Bum-Frick Montana
    Does anyone know what you can fit on a stock chevy rally wheel? I've seen some k5's and trucks running around with 33x12.50's on what appears to be stock wheels. Is that possible or is there another wheel size available?
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Re: Lergest tires on rally wheels?
    The widest tire you could fit on a 8" wide rim is most likely a 12.50!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    I agree. I had some 35 x 15 x 15 Ground Hawgs on the stock 15 x 8 ralleys once. It made the tire taller and wore it out in the middle of the treads. Looked goofy, too.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  4. Re: Lergest tires on rally wheels?
    I've got a 35-14.5-15 gummbo's on my stock rally wheels!
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I was at a car show on Sunday and one of the trucks there had 44 inch Gumbo Mudders on 7 inch rims!!! It was really bad, but he was driving it like that. It was wearing the center down really bad. I'd say 12.50 max on an 8 inch wide rim for good wear patterns.
    '73 K5
    Chevy good...Ford bad
  6. 85Blazernga
    85Blazernga Registered Member
    Mar 3, 2001
    44
    Georgia
    Do you have pics of the mounting bigbad?
    GSB
    Forever #3!!
  7. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I run/ran 35x12.5-15 on mine..
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  8. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    I'd agree with the other guys that 12.50 on an 8" is about the limit.....if you are crazy about Rally wheels and want a 10" version, Stockton Wheel can hook you up for $720 a set....that's unpainted and with all the shop gunk still on 'em.....I have a set of 6....I run 33" AT's on 8" for everyday and long highway trips....33" BFG Muds on 10" for play, and then I plan on 33/14 SSR's for the rear for when I Really play.....Hell, it's only money....JD
    I'm at 10th and Plum....10 miles from nowhere, and Plum out in the sticks....Stuck?...Hell no..I still got some gas left..
  9. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>FYI the last iteration of the ORD green Jimmy ran 37x12.5x15s on 15x7 OEM aluminum wheels. I agree, 12.5" is as wide as I would go with an 8" wide rim. While we're on the topic, has anyone ever ran a 38x15x15 Swamper TSL on a 15x10 wheel?</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  10. baldk5
    baldk5 Registered Member
    Jun 3, 2001
    29
    nova scotia, Canada
    i'm running 33-12.5's on mine. i never had ANY problems, i don't know if i'd run anything bigger.
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Running a 12.50" tire on an 8" rim should not cause any problems at all. One thing to keep in mind is that the taller the tire is, the more variance you can get away with between the width of the rim and tire. The reason is that there is more (taller) sidewall to flex so the transition from the width of the tread to the width of the rim is less severe the taller the tire is.
    On another note, I ran 32x11.50 tires on the stock 15x7 rims for several years and never had any problems.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friends run both 38.5x15x15s on 15x10 wheels and 44x18x15 tires on 15x12 wheels. No problems.
    I ran 35x12.50R15s on rally wheels too.
    Tim
  13. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Interco doesn't list a 38x15-15 TSL. They do list 38x12.50-15s and 16/38.5-15s, the recommended rim for both is a 15 x10.
    www.intercotire.com
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I never said that they were TSLs. My the 38s above are 4 Wheel RVTs, and the 44s are Gumbo Monster Mudders.
    Tim
