Last carrier question (I hope)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 3, 2004.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I had to drill into the carrier near the pinion shaft to remove the broken pieces of the retaining bolt. Is this going to weaken the carrier to the point that I should replace it do you think? could I weld it?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Go to Cascade Wrecking in Mill Creek and get another carrier.
    Bill
  3. dyeager535
    26,976
    I cracked the carrier on a buddies 7.5" in his S10 from trying to get that pin out, been driving it for like 5 years now. lol.
    If I cared about the axle innards I wouldn't just run it, but if I had a spare and wasn't planning on being too hard on it, why not? /forums/images/graemlins/smile.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i wouldnt worry about realy, unless you cant get a new lock screw in
  5. zach78k5
    May 14, 2000
    406
    The lock screw is fine and I am just using for a daily driver. No hard wear and tear.
