Last minute things
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k20, Jun 19, 2002.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok, in the next 2 weeks ill be priming and painting the bottom of my dash. /forums/images/icons/grin.gif /forums/images/icons/grin.gif Ok, 2 last minute things, how do u remove the arm to the brake release, and how do you remove the headlight switch on the dash? Ok, got the dash sanded, stuff you rub the dash with bought, primer bought, paint bought, clear bought, anything i might be forgetting? Thanks as always.
  2. dyeager535
    26,982
    190
    Headlight switch is fairly easy, on one side of it, behind the dash, is a small "button". Push that button in and pull on the knob like you are turning the lights on. If it doesn't come out, pull the knob out first, then press button and pull all the way out. Can't remember which it is anymore. After that, the black plastic piece on the cab side of the dash unthreads like a nut, and the switch comes out from under the dash.
    I don't know as the brake release arm is seperate...I *think* its riveted to the bracket, meaning the whole bracket has to come out. Amazingly, never had to remove one so not positive how it comes all the way out.
  3. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    thanks, ill try the headlight knob tomorow morning, and become a contortionist and figure out the brake thing if i can get up under that dash /forums/images/icons/crazy.gif
