Last year for Diesel Blazer/Jimmy??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bennett, Nov 24, 2000.
  1. bennett
    bennett Registered Member
    Nov 12, 2000
    45
    I was curious to know what was the last year for full size Diesel Blazer/jimmy and what tranny did they put behind those. A freind said they put some in the new style(ifs) But I have never seen one , I am more curious on the classic old style. Was 1990 the last?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    The last year for diesel K5's was the last year for K5's, 1991. They came with either the SM465 4 spd or the 4L60 tranny.
    [​IMG]FUN WITH 31's![​IMG]
  3. Glenn
    Glenn Registered Member
    87
    North Kingstown, RI/USA
    The newer ones had them too. Just in case anyone is wondering. I have seen just one though.:)
  4. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I once found a 94 that was on a lot for sale . It had a 6.5 .
  5. chevy4x4
    chevy4x4 1/2 ton status
    Apr 27, 2000
    1,454
    I think 6.2 was from 82-91 and 6.5 from 92-??
    [​IMG]K5[​IMG]
  6. Dave
    Dave Registered Member
    Apr 23, 2000
    63
    Grafton, Wisconsin
    Even though it didn't carry the Blazer name, the Tahoe (same truck, diff. name) in 2 door form had a 6.5 until 1999.
    Dave Hiller
    90 K-5 87 K-5, 84 K-15, 96 9c1 - Please don't slow down in front of me!
  7. militaryblazer
    militaryblazer 1/2 ton status
    Nov 14, 2000
    235
    Azle, Tx
    In 1991 was the auto tranny a 4 or 3 speed and what transfer case was behind it. I have an '86 Diesel Blazer with TH400 and 208, and I want a 4 speed auto.
    <font color=orange>'86 Military Blazer with 4" Lift & 33" Tires</font color=orange>[​IMG]
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    486
    Grand Rapids area
    Good Luck. The only 4speed autos are the TH700R-4 and the 4L60E, which are the same tranny, except that the latter has electronic controls. It is generally understood that these are about on par with a TH350 when done right, but they are not as strong as the TH400.
    Here are some key questions:
    -What transmission is the 6.5 TD usually mated to?
    -Is this tranny a 3 or 4 speed?
    -What kind of adapters are needed to mate this tranny to a 6.2?
    "They tell me that you can make it to work without big tires. I'm still not convinced."
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I have a '90 K5 with the 6.2 and it is backed by a 700r4 (aka 4L60)and a NP241 case. To the best of my knowledge, the civilian models back to at least '86 were equipped with the 700r4 except for the military CUCV versions which I believe had the TH400.
    The 6.2's also have the same bellhousing as the gas engines so they should interchange, transmission wise, fairly easy.
    I know the 6.5 turbos were available with the 4L80 in the 3/4 and 1 ton trucks, though I'm not sure if either the 4L80 or the 4L60 was used in the Tahoes or not.
  10. Dave
    Apr 23, 2000
    63
    Grafton, Wisconsin
    If it's automatic, then a 4L80E is used. If the vehicle is stick, then a 5-speed (MW3 option) trans. is used.
    They 4L80E is a 4-speed automatic.
    4 -&gt; 4-speed auto
    L -&gt; Longitudinally mounted (a.k.a. "The Long Way")
    80 -&gt; Model Designation
    E -&gt; Electronic shift Transmission
    I would assume no adapters would be needed. GM uses a 6.5 as a direct replacement for the 6.2, since 6.2s are no longer made. Should directly bolt in.
    Dave Hiller
    1973 Chevy K-25
    1996 Chevy Caprice x-cop car
