Late model Chevy/GMC rear disk brakes on 14bff?
Discussion in 'The Garage' started by 88K5Jimmy, Oct 29, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Late model Chevy and GMC trucks have had rear disk brakes for a couple of years now. Could you use the disk brake calipers off of the heavy duty maybe even the light duty trucks on our K5's? I know there has to be an e-brake on them some kinda way. Has anybody attempted to do this yet on 14bff?
    What do you guys think?
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I had that same thought the other day, good post... /forums/images/graemlins/wink.gif
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    Anyone car to chime in here and tell us how stupid we are.....? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/tongue.gif
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    you supply the parts (with the exception of the 14b), and i'll build it.
  5. harry
    harry 1/2 ton status
    Feb 9, 2001
    106
    san diego, CA
    I have a 2002 3/4 ton 4x4 Sub and was wondering the same thing. The ebrake cable runs down the driver side to the peddle. I think it would be fairly easy to put this in my 69 k5 and make it work but how much do these parts cost /forums/images/graemlins/eek.gif. They are so new they are probably are only dealer items /forums/images/graemlins/smirk.gif. ("Hi, AAA (auto insurance), somebody just stole my two front bucket seats, my third seat, and my entire rear end. I can't believe it happened in my driveway and I didn't hear them). J/K/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ] Are the seats leather if so where do you live..? /forums/images/graemlins/smile.gif
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I was thinking you could do everything to put disks on a 14bff but use the calipers from a late model Chevy/GMC (if they fit) as an alternative to Caddy calipers.
    But I don't know if they would bolt up to the existing brackets being sold on here and if the calipers would fit over the 3/4 ton front hubs used on a 14bff
    Harry maybe you could take some measurements of the rotor thickness and diameter and could compare with someone that has the 3/4 ton rotors used on a 14bff disk conversion
    Maybe a starting point?
  8. harry
    Feb 9, 2001
    106
    san diego, CA
    sure thing 88Jimmy. I have the TSM 14b disc set up on my 69 in the garage. I will take measurements (sp) and reply tomorrow afternoon.
  9. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I did some searching and this is what I came up with. I looked at Grim-Reaper's pics of the late model 6-lug Chevy rear disks and IF the 8-lug set-ups are the same then the only things I can think of to make them work would be:
    -having enough clearance after its all done to run a 15" wheel
    -if the brake caliper would even be big enough to "grab" the rotor once you got the 4WD front rotor and 14bff hub assembly together
    (perhaps the need for a spacer to space the hub/rotor assembly away from the axle)
    -having your e-brake and hydraulic brake line fittings match
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm interested in this. Can you take a pic of your rear calipers? Maybe one that shows how the parking brake works?
  11. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    If they are the same as the rear disc setups on the 2002 Silverado's then here's how they work. They are a rotor with a drum in the middle. The drum is pretty small in size and it's for the e-brake. Then the rest is all the same. So to try and explain it better the middle of the rotor has a small drum maybe 6-7" across with a cable going to it that is the e-brake and the caliper works the same as any other rear disc setup. Later
  12. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Only the 1st 6 month or so of the 2001 run use the 14 ff. from then on it a 11 1/4 ring gear made by AAC.
  13. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    *EDIT*
    In my previous post I said that the brake rotor that could be used would be the front rotor off of a 4WD straight front axle. However, in order to utilize the e-brake function of the late model Chevy disks, you would have to use the rotor off of the late model Chevy disks. Now the question would be if the 14bff hub would sit inside the late model Chevy rear disk rotor, letting the e-brake actuate.
    Blazer79 I can't take pics because I don't have a late model Chevy with rear disks. All I am going off of is Grim-Reaper's pis of late model Chevy 6-lug rear disk setup. The rest is all in my head, but I don't know if it will work or not. /forums/images/graemlins/tongue.gif
  14. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I'm into this too.....Just got the 14FF last night and got to looking at it for the disk brake switch over. I have 6 lug rims and a Dana 44 on the front going to machine up a new hub for the 14FF to hold the 6 lug rims I have. I would then be able to put on the Dana44 disk brake rotor and just fab up a bracket to hold the caliper on. That way the rotor would fit my rim and I would not have to worry about clearance issues on the caliper. Would have to find a caliper with an e-brake set up to hold the truck in park. Need to check a front disk for the fitting on the rear shaft but from looking at it, I think I would only have to bore out the center hole to slide over the axle housing.
    Any one done this, have any suggestion.
    Will keep document on this if it works
  15. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    someone on this site did what you want for six lug 14 bolt.they just took a rim and centered it on the hub and marked where the holes lined up.then drilled it out and they put a dana 44 rotor on it with longer than stock studs.then they built a disk brake bracket and used front brake calipers for a 44.i wish i had entered the link into my favorites so i could give it to ya.
  16. TONYP
    Aug 13, 2002
    2,116
    so cal
    I’m thinking about setting the hub up on a CNC machine, I would cut the inside of the hub leaving the 8 lug bolt pattern but getting a clean surface to make a matching ring/spacer with the 6 lug pattern, the spacer would be machined to fit around the new machined surface of the hub with a .005 clearance, this will give me the proper thickness to mount the new rotor on plus I will have even more contact between the rotor and hub. Then I would drill and ream the 6-lug hole pattern into the hub, I would then install the rotor and spacer with the wheel lugs. I can machine up the mounting bracket for the caliper and bore out the center hole in the rotor…My thinking is that by doing it this way I can use the front Dana44 rotors and calipers…. But no e-brakes
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    Look what I found......any body kinow what its from?????
  18. TONYP
    Aug 13, 2002
    2,116
    so cal
    anybody have info on the caliper??? /forums/images/graemlins/ears.gif
  19. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    Just guessing .. but looks kinda like a Thunderbird Turbo Coupe (87 - 88 ish) rear caliper. Maybe an 84-86 SVO Mustang rear caliper.
  20. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Could even be F150/Expedition/Navigator.
