Late model keyless entry in our rigs?
Discussion in 'Audio' started by 88K5Jimmy, Jan 1, 2004.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Is there a way to install a late model keyless entry system into our K5's? I would like the setup that is similar to my parents Yukon. You press the unlock button once to unlock the drivers door and twice to unlock the rest of the doors. Then if you wanted to be tricky you could wire the rear hatch button to roll down the rear window or something?
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    A Black Widow alarm rolls of the top of my head. Has all that and then some. There are quite a few brands out there that will do and surpass what you described. /forums/images/graemlins/thumb.gif
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Yeah basically you'll have to install an alarm system of some sort. But it'll do the same thing from the key fob and probably be more reliable than the GM version.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    CODE ALARMS !!!!!!!
  5. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    CODE ALARMS !!!!!!!
    [/ QUOTE ]????????
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's a name brand. CODE ALARMS is one of the best IMHO. Can't beat thier top of the line system. They garentee if it get's stolden, they'll replace your vehicle. It uses satalite tracking, and does everything "Onstar" does. They can even shut the vehicle down if you call in after a car jacking. Shut it down and lock the car jacker in till the cops get there. /forums/images/graemlins/thumb.gif Lots of options with CODE ALARMS.
  7. 4GUNZ4X4Z
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Oh got ya. Never heard of it.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    If you have power door locks than any good alarm will have the keyless feature. I have a top of the line Ungo alarm with remote start, silent arm/disarm, but I don't have power door locks but I will soon.
  9. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    But older rigs aren't setup for the one feature that he seems to want the most. Unlocking the doors is easy, but he specifically wants the "press once to unlock ONLY the drivers door" and "press twice to open ALL the doors" feature that late model vehicles have. Unlocking only the drivers door prevents someone from jumping in on the drivers side when your wife unlocks the vehicle in the parking lot at the mall. /forums/images/graemlins/shocked.gif
    It could be done on an older rig but it would require some rewiring of the door lock circuits.
  10. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
  11. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I had one installed on my old blazer but I did not have power locks. However, it did have the feature you described allowing you to unlock only one door. It worked well but the keyless start is a little difficult if your truck is carbureted. That is unless it fires up without the choke.
  12. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    There are systems out there that will let you use the unlock one door feature, if the vehicle came with that option from the factory. All the lock circuits on our rigs are wired to a common set of relays though, so all the doors either lock or unlock together. Changing that would require rewiring the lock circuitry into the drivers door. /forums/images/graemlins/frown.gif
