Late model rear ends narrower?
Discussion in 'The Garage' started by CHEVY 4WD, Jan 18, 2004.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Im still trying to find a SF and was told that newer trucks with SF rear ends are about 3in narrower ... is this true? If it is is it a total of 3in or 3in on each side? Also when did the different widths happen (year wise)?
    Also If I put a newer rear end in my truck will I have to re-weld the spring perches('84 ½ton) /forums/images/graemlins/thinking.gif
  2. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Nope, the later model 4wd rims have much more offset than the older rims and to compensate just made the rearend wider. I have seen when guys do a solid front axle swap on newer trucks and the track width is almost perfect because the late model rearends are wider than the earlier ones. /forums/images/graemlins/thumb.gif
  3. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    how much wider? I was thinking about using my 8-6lug adapters on a new rearend but then it would look REALLY goofy and probably even rub the top of the fender when I flex
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    new model rear ends are 3" wider than older ones, to compensate for the IFS and wheel differences..
    toyota did the same thing in 86 when they went to IFS..
  5. ijakers
    ijakers Registered Member
    Apr 2, 2003
    34
    St. Martinville, Louisiana
    so would the newer model rear ends be the same width as the front axle on an 86 k5?
  6. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I know for a fact the 88 and newer 2wd 14BSF is narrower than our trucks. I tried swapping the axleshafts from an '89 2wd sf(6lug) into an '84 2wd 14bSF (8lug)right in the local upullit place, the '89 axles lacked about 1 inch from getting the c-clips in. Thought I had a clever way to get a bolt in 14BSF 6 lug into my K5...just outsmarted myself so I ended up putting the 8 lug axles back in and converted to 8 lug on my K5. The '88 and newer 4wd 14BSF is wider than our trucks and will require spring perch moving/welding.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    could be an issue of brake shoes width though
    did you measure shafts themselves to compare ?
    or measure housing widths?
  8. dyeager535
    26,976
    From what I recall, if anything, the newer axles are wider, but no more so than the 3" it takes to "equal" our front axle width. /forums/images/graemlins/thumb.gif
  9. RedBrute
    Sep 22, 2002
    346
    I did not measure, I was doing all the swapping right in the junk yard. after I tried the newr model axles, I stood new and old on end and saw the difference between them and gave up.
