Later center bolt valve covers don't work with TPI
Discussion in 'The Injection Section' started by dyeager535, Feb 23, 2007.
  1. dyeager535
    26,979
    Well, they can, just not right.
    Yet another lesson learned, at least it wasn't too expensive.
    Since I realized the MAF/oil filler issue, I decided I wanted a later model style oil fill, the screw in type.
    At the last swap meet, picked up a nice pair of Vortec take offs.
    Turns out the oil fill is at the rear driverside, which places the PCV at the drivers side front, opposite of what (my) TPI setup needs, PCV in back. I think even the passenger side breather is at the back too, which is wrong as well. :(
    I wonder if the Corvette setups are similar to the Vortecs then, I know even the Vette TPI motors are somewhat backwards compared to Camaro ones.
    Thinking I might run a longer line for PCV, but that sure makes it hard to reach the oil fill cap. The one I remove maybe twice a year if the truck is lucky lol.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Why not use valve covers from an 89 blazer. They are center bolt covers, screw on oil fill on drivers side front, breather is on the driver side rear, PCV is on the passenger side rear.
  3. dyeager535
    26,979
    Hmm, maybe I could combine them. :)
    My breather is on the passenger side front, so I could keep the passenger side, just need the drivers side with the breather/PCV (same baffle setup internally) at the rear.
    I'm sure you've got one to send me, right? :)
    Maybe I'll ask in the parts wanted section. Thanks for the insight, I wondered about the older centerbolt valve covers!
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I do not have any to send you. I am looking for another driver side cover myself that uses the screw on oil fill cap. If anyone here has 2 of them Dorian gets the first and i could use the second one. I have several sets of the push on oil fill type though.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That goes for '91 too.
