Later model GM transmission question...
Discussion in 'The Garage' started by kp texan, Jan 11, 2007.
  1. kp texan
    kp texan 1/2 ton status
    Sep 8, 2003
    211
    Corpus Christi, TX
    I know this isn't quite K5 related but I trust you guys more than anyone else when it comes to GM related topics.
    I'm looking at later model GM Trucks (Silverado 2500 and Sierra 2500, 4x4, 2000-2002 models) and I can't seem to find which transmissions GM mated with the Vortec 6.0L engine. Did they use the 4L80E like a 3/4 truck should have, or did they use the 4L60E just like they do with the Vortec 5.3L, or could you get either with the 6.0L? I know the Dmax and 8.1 liter were available with the Allison but I've searched around and can't figure out which specific transmission the Vortec 6000 used. How about rear ends? I'm assuming the 3/4 tons used 14bolt sf?
    Thanks,
    Wes
  2. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    4L80E? 14BFF? I think... I'm sure it depends.
  3. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    i bet 4l80-e with the 6.0 and look for a tapered in back side of the pan. not all square at the corners. and the alison is easy as it has a spin on filter on the front left corner.
  4. kp texan
    Sep 8, 2003
    211
    Corpus Christi, TX
    I've been looking on autotrader so it's difficult to figure out. I wish it was as simple as figuring out the engine thats in the truck (just look at the 8th digit in the VIN). Apparently the transmission is just listed in the RPO codes on the tag but that info isn't exactly on autotrader.
    Thanks for the replies,
    Wes
  5. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    all the 6.0 i've seen have the 4l80, but i've heard they have the allison as an option.
  6. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    6.0s only came with a 4l80e, you have to get a big block or a Duramax to get the Alison trans. The rear end would be a 14 bolt semi float in a 1500 or 2500, while the 2500 HD would have a 14 bolt full float.
  7. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    2500HD could also have an Eaton in certain years. 2004 for sure, I think 04+.
  8. bigblock72
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    I don't think they ever put in a 11.5" AAM in a 2500HD, possibly in a 3500. Not very many 3500s with a 6.0l so I'm not sure on that.
