Later model ORD Shackle flip and springs onto a 71?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by grendel, Feb 3, 2004.
  1. grendel
    grendel 1/2 ton status
    Jul 5, 2002
    287
    Boston, MA
    Howdy,
    My project plans just changed, as I purchased a 71 Jimmy.
    Anyone know if lift springs and a ORD shackle flip from an 81 would fit this?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I think the shakle flip will work fine but I am guessing?
    The springpacks need to be mesured from eye to eye then from eye to centerbolt. If they are the same then they can be used /forums/images/graemlins/thumb.gif
    Good Luck
  3. grendel
    Jul 5, 2002
    287
    Boston, MA
    Thanks, but I was hoping someone would have measurements for me!
    I have a set of rear 4" lift and 56" long that I want to use.
  4. Burt4x4
    6,854
    oh...I think I put 56" SuperLift 5" springs in my K5's rear. I will have to double check but I think that is waht I put in. I know the part number from Superlift was for a 73 and Up Chevy PickUp. Ya I think it was 56" cuz I remember eye to center bolt being 28".
  5. grendel
    Jul 5, 2002
    287
    Boston, MA
    Nice, thanks for the info. Those are the identical springs I have for the rear. What did you use in the front? /forums/images/graemlins/thumb.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Howdy,
    The springs will fit, the shackle flip will NOT.
    I'm running a pair of '89K5 springs on the back of my '72. It's a nice combo by the way.....the late model springs are a lot softer from the factory than the 1st Gens ever were.
    The ORD Shackleflip will not work though, the later model frames are narrower, so the bracket has more "offset" to compensate. If you install them, the rear spring mounts will be too far apart on a 1st Gen. /forums/images/graemlins/dunno.gif
  7. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    You can just swap the 2nd gen springs in without any modification at all Greg? I thought you had to move the hangers for 56". /forums/images/graemlins/thinking.gif
  8. Burt4x4
    6,854
    I have Rancho 4" up front.
    My Superlift rear springs just bolted in with no mods required /forums/images/graemlins/thumb.gif
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I have no idea what you are talking about. /forums/images/graemlins/dunno.gif
    FRONT springs are different lengths between 1st Gen and 2nd Gen, but the REARS are the same length....
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Greg, it is my understanding that the frames are close to the same width, it is the difference in OEM spring hangers on the rear that is the concern. I compared the hangers on my '77 parts truck to my '71 Burb and the '77 hangers hold the spring away from the frame 1.25" further.
    This is why the pre-72 spring perch distance is 40" and the 73-later is 42.5". /forums/images/graemlins/thumb.gif
    I suppose it is possible to use the later flip on a "1st Gen" if you used the later front spring hanger and have the correct spring perch distance. /forums/images/graemlins/waytogo.gif
  11. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    a valid correction.... /forums/images/graemlins/waytogo.gif
    The springs are further apart, but because of hanger differences, not frame differences.
    /forums/images/graemlins/bow.gif
  12. clubba68
    Dec 6, 2002
    1,511
    Those last couple posts went over my head for some reason. Must still have my mind on accounting. So the 2nd gen rear springs will bolt right up with no problems when I throw my echobit shackle flip on there?
    Sorry, I'm in my own little world. /forums/images/graemlins/smirk.gif
  13. grendel
    Jul 5, 2002
    287
    Boston, MA
    You have 4" Rancho springs for what year/model?
  14. grendel
    Jul 5, 2002
    287
    Boston, MA
    My understanding is that the rear springs will fit without any mods.
    The spring to frame spacing is different from the 1st gen to the next gen.
    Your shackle flip won't work without changing the front spring mount and the spring pads on the axle.
    For me, I've already cut off the spring pads from my axle. I may just get this to work...
    Now I have to figure out what to do on the front. I have some '81 6" lift springs I was hoping to use...
  15. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    All K5 rear springs are 52" long. Some 3/4-ton's and all (?) 1-ton's came with 56" leaves that you would have to move the rear hanger back to fit.
    88 and up trucks came with 63" leaves.
  16. clubba68
    Dec 6, 2002
    1,511
    Thank you Dan.
  17. stretch67
    stretch67 1/2 ton status
    Nov 1, 2003
    171
    bozeman mt
    i used 2nd gen spring hangars on my 71 frame. the frame holes don't line up. they are close but not close enough. i had to weld up the stock holes and redrill new ones based on the newwer hangar ones.a couple things to think about are with 2nd gen hangars you get 2 more inches of lift compared to the 1st gen because the later ones are longer. a 4 inch lift for a 1st gen uses 6 inch 2nd gen rear springs so make sure the shackle flip will work for the lift you want! it's easy enough to redrill the frame but if you use 2nd gen shackle flip you also need 2nd gen front hangars also if you already narrowed the perches on your axle you might be money and time ahead buying a 1st gen shackle flip and still using 56" springs /forums/images/graemlins/grin.gif
  18. earl87gta
    earl87gta 1/2 ton status
    Apr 6, 2003
    551
    Chuckey TN
    Dont mean to steel the post but if I am going to add a 4 lift spring on my 72 then I need a 6in lift spring for a secongen blazer. Im thinking of going with bds springs and dont want to have the springs came with 2in block problem I dont want the 2in block that I have read some poeple didnt account for.
    Thanks.
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    As far as I know needing the extra spring height in the rear has to do with a few things.
    1) The springs were designed with a p/u in mind which has less weight in the back end (if we are talking about a hard top it makes even more of a difference).
    2) The front wheel opening is much larger than the rear. Most people like the look of "equal tire gap" so the back needs to sit up a bit higher than the front.
    I don't think it has much to do with the spring hanger differences.
    Most everyone I have seen with a 1st gen with 4" in front and 6" springs in rear and has been happy with it. I have also seen a few 6" front and 8" rear that the owners were happy with.
  20. earl87gta
    Apr 6, 2003
    551
    Chuckey TN
    who has 8in rear springs for a first gen?
