LAV military tires on a stock 16" chevy rim
Discussion in 'The Garage' started by 84CUCV, Jul 18, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    these are the tires i just bought some of. I was told they are LAV tiers. anyone know sure what they are?? Now that i have seen the and moved them. they are heavy and look hard to dismount. as always thx
  2. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    yup them be LAV tires:wink1:
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    look like Michelin XLs
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Is the LAV the same as the stryker. Our local surplus dealer says they mostly come from strykers. My buddy just bought the xml version of it looks mean on his truck heres a pic
    They have a run flat insert in them you have to saw out, I kid you not.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thx guys so they are going to be fun to dismount......great.
  6. goldwing2000
    goldwing2000 Guest
    Mostly the same. Different branch of service.
    Are Strykers amphibious?
  7. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Ractchet strap out the runflat to make it fold like a taco and LUBE LUBE LUBE:crazy:
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    What do you mean throttle boss??
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    just took a good look at them. Are they a 2pc rim or something likr that? I dont see how to get them apart at all.
  10. az88k5
    az88k5 1/2 ton status
    Oct 14, 2004
    258
    Prescott Valley, AZ
    Yep those are Military Michelin XL's. Have fun taking those wheels off. I sure had fun watching my friends get them off. One dismounted every half hour if your lucky enough to have the right tools. Beat the rim with a BFH then beat the tire down away from the rim. Then try to get the c-ring out with a air chisel hammer work the c-ring out and your almost there. Once you get the c-ring out the ring will come off and the tire is ready to come off the wheel. Oh and the run flats are easy pry away from tire and cut with a saws-all. Have fun with those tires. My friend is running those on his F-350. They sure are loud. I will be running the XZL's myself like the red K5 Blazer
    I am selling some of these tires for a friend in AZ if anyone is interest they are in the classified section under Tires and Wheels:
    http://coloradok5.com/forums/showthread.php?t=179203
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thx sounds like i have alot of work in front of me. i just got a few sets....
  12. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    they are worth the work I saw the type you have a couple of years back on a full size pickup aired down they had tons of traction
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Cool good to know
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    it this a beadlock rim like the h1 rims?
  15. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    xl's
    I run them (XL's)on my k20 and love them, they are truly awsome off-road. I run 10 psi in front and 8 in the rear now. 20 psi is plenty for the highway and my truck weighs 6200 lbs!! The bead lock/runflat setup is similar to the hummer but the wheel is TOTALLY different. the best way I have found to dismount them : slide tire under something heavy( i used my 23'000 lb mechanics truck), use bottle jack on bead flange to compress the runflat, peel out some of the lock ring w/ pry bar, and use an air chisel to peel out the rest of the lock ring. pull off the outer bead ring, rubber seal, and if your real lucky you can push the wheel out of the tire and runflat, cannot stress enough how much easyer lots of lube like ru-glyde makes this. then it looks like the easyest way to get the runflat out is to push it to one side and cut it. I used a truck mounted crane, 2 nylon straps and plenty o-lube to pull the runflat out of the tire. here's some pics - my truck goin' through the Golden Crack in Moab(@ 15 psi - too much, 10 is way better) View attachment 33233
    XL's on 6" lift and lots of trimming(actually had to trim lots more than this shows)
    this shows the runflats and the wheel
    and another Moab picture cause I like it:D
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    looks like a lot of fun. thx for the information. thx
