Lead shot, Steel tubes
Discussion in 'The Great Outdoors' started by 454k30, Jun 25, 2006.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I just bought my first autoloader, the SPR 453. Made by Spartan, and imported by remington. These gun seems very well built and came with 4 choke tubes all rated for steel shot. My question is if I can fire lead shot through these steel choke tubes? I have heard not to fire steel through lead tubes but how about the opposite? Seems to me that the softer lead should easily pass through these tubes but I just wanted to ask some more experienced shotgunners. Thanks for any info or pointers you might have.
  2. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    quick answer: Yes, you can shoot lead through them without damaging anything.
    Some will claim that the pattern will be a little different, but you should always pattern your gun anyway so you know what it is doing. (They are all a little different)
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    As said you can shoot lead thru steel shot tubes. Choke tubes for steel shot are larger diameter than lead choke tubes. A full choke steel tube is about the dame diamater as a modified choke lead tube. Reason they are larger is steel does not compress when going thru a choke as easily as lead. If you compress steel shot too much it has a tendency to spring apart when leaving the barrel. Causing a wider or deformed pattrn.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yep, like they mentioned it is ok to shoot lead threw steel tubes. If you are shooting lead threw a FULL choke for steel it is mod. Each tube is 1 choke less with lead.
    Harley
