lead time on motor mounts update
Discussion in 'OffRoad Design' started by Seventy4Blazer, Jan 23, 2004.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Ordered them friday, got them today. opened up the box to see them to find that they are slightly different. meaning one upright on one motor mount is mounted 1/8th inch different than the other mount(talking about the frame mounted portion) is this going to affect anything?
    also they have a tall side and a short side(still talking about the frame mounted portion.) as in the angle is different and it would affect the distance between the mounts on the frame... how do they go? i cant try to set the motor in untill i get my spring plates for the D60... so i ask now so it will be easier to install and only take one shot at it.
    thanks
    Grant
    want to order some polly motor mounts VERY soon.. how long does it take to make them? or are they on the shelf?
    Grant
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: lead time on motor mounts
    We have the Daystar poly mounts and the comp style mounts in stock now, no problems.
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    thanks, ill be calling you soon i think.
    Grant
  4. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    TTT update on top post
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think when you go to bolt them in, you'll find the bolt pattern will only let them install one direction. They can be a pain to get in there, not many GM frames are really straight any more but they're usually not impossible.
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    ok, im waiting on a few other parts before i set the motor in. tonight ill do the mounts tonight to see how they should go in. then put them on the motor before it goes in.
    thanks for the reply.
    Grant
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    yup, im a jackas$....
    they do have holes that are spaced differently.....
    i have yet to drop the motor in, but i got the mounts put on the motor.
    i have found that when putting new mounts in its easiest to put them on the motor and then bolt them to the frame once the motor is in.
    just need the spring plates and all will be good.
    Grant
