leaf lifts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Dec 28, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Is it true that you can add leafs to your leaf packs in order to get lift? If so how is this done? And is it a safe andrelaible way to lift your tru /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gifck?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    People have done this. I have personally seen a 14 inch thick leaf pack once. Its not a good idea. You will end up with a much rougher ride. depending on how much you add, it can start to get unsafe. You could try an add aleaf or find some used springs if your out to save a buck. People sell springs here quite a bit.
  3. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Well I was thinking a four or 6 inch lift? Would that be too much to add to a spring set up?
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    If you add enough leaves to get 4 to 6 inches of lift It will ride like it has no suspension at all. Like he said look around or try ebay. Try a shackle flip if you don't already have one. That is 4" and cheaper than springs.
  5. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I for one can tell you that adding leafs gives one crappy-ass ride!!!!
    When I bought my truck, someone had put on what I'm guessing are 3/4 or even 1-ton springs (7 leafs!!). Yes it is lifted (I'm guessing 5 inches) but yes the ride is VERY stiff. The only reason I keep it is because I don't want to spend the money and tell myself I can live with it (plus not much flex) and also 'cos I tow a big boat.
    Don't do it!!!
    Get the shackle flip!!
    smack
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Best thing to do is just pony up the cash and buy a lift kit.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I'll have a set of 4" blocks for sell soon, I'm putting my 14FF with shackle flip on....
    you can do different lifts depending on the moneys you want to spend.
    1-Shackle flip
    2-New 4" leaf springs
    I am putting the Echobit shackle flips... flip kit
  8. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    I got 5" 's of lift by adding a 1" add-a-leaf (tuff country) to my stock pak. (oh ya... i had 4" blocks) I kept the factory overload, but just flipped it upside down so it only provided lift and not support. This worked great, rode fine, and held up for years.
  9. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok scratch that idea.
    So If I were to get the echobit shackle flip I can gain four inches of lift in the rear and keep my stock springs? How hard is this to install. It looks cheap at only 90 bucks.is this better than buying 4 inch lift springs for the rear? /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  10. TONYP
    Aug 13, 2002
    2,116
    so cal
    you would have the same ride you have now and you just unbolt you leaf springs from the shackle and then unbolt the shackle from the hanger, then just bolt the flip and you leaf pack on...
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You'll get more like 6" in the rear from the Echobit flip. How do I know? I have it.
    In my opinion a shackle flip is better than springs, but there are advantages to both. It just depends on what you're going to use your truck for.
  12. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I wouldn't say that the flip or lift springs are better than each other without first looking at what your trying to accomplish. Most inexpensive lift springs tend to ride stiffer than your stock springs for a variety of reasons. This can be a good thing if your trying to stay rigid for cornering or towing bigger loads but can hurt your ability to flex out unless you have alot of weight (both truck and drivetrain) to really push them around. Running softer springs adds more lean in the corners, results in a softer overall ride and takes much less weight to articulate the axle and conform to obstacles. Its not untill you get into the higher end lift springs like Nationals where they tailor the springs directly to your truck by weighing both ends and custom building the packs to generate your desired lift, travel, and spring rate, that you get into a softer than stock ride from an all spring lift (unless your a 3/4 or 1 ton). The flip (regardless of who's flip you buy) is about the least expensive way to stay soft, and with cross platform spring swaps like the 57" Ford F150 leaf pack adaption you can begin to get rediculously soft and flexy with a very small investment. As for difficulty in the installation, TonyP is right, both the shackle flip and lift springs require unbolting the stock leaf pack and at elast loosening the spring plate. With the flip its just to work the spring around the stock hanger and doesn't require bench pressing the pack off the truck like a spring replacement does (unless you have a lot of lift and can pull it out over the tire like me! /forums/images/graemlins/grin.gif ).
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Tim is right on the lift as well, the kit can provide up to 5 3/4" of lift. Trucks tend to get more lift since there is very little weight on the rear springs, blazers tend to get closer to 4 1/2" of lift due to the shell, seating and weight distribution. I had one person call back because his stock springs were so worn out, he only got 3 1/2" of lift from the kit so it will be relative to your current springs condition and if they are sitting low, stock, or high.
