Leaf Spring Bolt???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rolled, Oct 31, 2002.
  1. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    One of the bolts on my front springs has broke. What is this part called and would Pep Boys have them? I suspect it has a more elegant name than leaf spring bolt /forums/images/graemlins/grin.gif
    Also, on one of the spring perch/pads the hole where the bolt from the springs rests, the hole is slotted. I assume this is for alignment, right? If so, how to I adjust this?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's called a spring center pin.
    And for the slot in the spring perch, it would be logical to have it for alignment issues, but I have yet to see one like that. Al the ones I have seen are just a hole and I think it's because this pin is used to positively locate the axle so you can't really rely on the U bolts to hold it centered, it could slide.
    Are you sure it's not just worn out and elongated?
  3. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Thanks imiceman44
    I'll have to look when I get home but I was prety sure it was a machined slot. It was only on the drivers side. It was a 10 bolt from an 87. I have not looked at the 10 bolt 3.73 from an 83 that I'm replacing the 3.08 with. I just assumed thay all had the slot.
    I'll double check tonight.
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I looked a both the front ends and they both have the slot but it is right to left. Not front to back like I thought so I guess it is to provide a little installation wiggle room.
