Leaf Spring Bushing Question
Discussion in 'OffRoad Design' started by sandawgk5, Aug 15, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I run a full set of ORD greasables and I need to change springs in the rear. Question, can I reuse the bushings ? I would check them of course and replace if damaged. I only have about 1500 miles on the bushings.
    Ira
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    as long as u don't damage them when u remove them, and there the same size bushing for the new spring u shouldn't have a problem...
  3. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    x2:D
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    X3-ORD
    Spring bushings are not one time use items Ira. :D
  5. sandawgk5
    Oct 28, 2003
    6,881
    I figured but wanted to be sure. Knowing my luck I would find springs that had different spring eye sizes than the ones I already have:D . Also for 2.5" wide springs in the front can I just use the same bushings as for the rear just put a 1/4" spacer on each side to make up the difference?
    Ira
  6. sweetk30
    Nov 1, 2004
    25,554
    548
    yes and kirt at dyi sells them just for that.
