leaf spring bushing removel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DALE, Mar 23, 2001.
  1. DALE
    DALE Registered Member
    Aug 27, 2000
    44
    hey everbody today i just recieved my new rear leaf springs from springs and things in danville PA anyway they came with rubber bushings and i want to remove them and put poly bushings. how do i take the rubber bushings out and get the poly's in. please help.
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Piece of cake. Take a 1/4 drill bit(with a drill) and drill holes in between the eye and the center bolt. The more holes you drill, the more rubber you remove, and the easier it will be to remove. Good luck
    creepin' and crawlin'
    Jim
  3. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    I just took out the inner metal sleeve and used a hammer and old large socket to pound on to knock them out.
    <font color=red>Spirit of 76</font color=red>
  4. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    I've also heard of using a torch and melting them out, but take your time and don't get the spring too hot. You could ruin the temper.
  5. k5king
    k5king 1/2 ton status
    Jul 23, 2000
    571
    Parkesburg, Pennsylvania
    if you have access to a small press that would be the best way,, if not than it will be a long trip getting them out,,at least mine were on my old spring's,,i drilled them out and also used the torch along with a good sharp chisel and hammer...the new poly ones go right in,,,i suggest you never sieze them too,,makes less friction going in and also keep's them sliding for flexing.
    ANYBODY LOSE THEIR JEEP????????[​IMG]
    I JUST FOUND ONE UNDER MY BLAZER!!!![​IMG]
    [​IMG][​IMG]
  6. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Just hit them with a small torch and lite them on fire. Then you can pop them right out. Don't keep the torch on there too long or you may mess up the metal. The burning rubber is not hot enough to hurt anything. Do this outside. You can then remove the thin metal sleeve with an air hammer and a muffler cutting bit, a hammer & chisel are slower, but will work, too.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  7. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    This is the easiest way I have found if you don't have a lot of tools (Torch, air chisel, etc.) Take one of the cheap propane torches that screws to the latern fuel type bottles and place the tip just inside the bushing eye. Let it sit for a few minutes and the sleeve will be so hot the rubber will have melted away and you can pull the bolt sleeve out with a pair of pliers. Take a drill with a 1/8 bit and put it between the bushing and the eye and it will rotate around the bushing and pull it right out. To get the sleeve out of the spring eye simply take a hacksaw blade, put it through the eye, and reassemble the hacksaw. You can cut through it in no time. This method keeps from ruining the spring temper and requires only simple tools.
