Leaf spring bushings, poly or rubber
Discussion in 'The Garage' started by tch777, Dec 9, 2005.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Okay so I have to replace my stock bushings they are wasted.
    I replaced a set of these on my old 76 F150 before and I used the drill out the and push the rubber out method with a ball joint press to do the pushing. That is until I broke the press, it was a cheap JC Whitney press.
    So I am going to prepare better this time a buy some of the correct tools to make this easier on myself.
    I can pick up a 6 ton hydraulic press or another ball joint press.
    Which will work better? I had to use an impact wrench on the ball joint press to get the other bushings out. Will a 6 ton press be enough to get er done?
    Also I am going to put in either the ORD greasable bushings or get rubber replacements. If I go with the rubber replacements will the 6 ton press be able to press them in? Or will I still need a BFH and a new back when finished. I would really like to see some one post if they re installed factory rubber style bushings at home.
    Also I need to cut out a couple bolts as they have fused to the old rubber bushings. I am going to get a new Sawz all from Sears. What blades work the best? And is it possible to cut the bolt out on the inside of the spring hanger without destroying it?
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Use the ORD method, burn & drive-out the shell. Do not replace w factory rubber. Wrench the bolts until they unscrew or snap.
  3. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    ord greaseable units. should be the last set you need to buy. i love them. and thay are on sale now i think.
  4. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    I'm in the process of doing this to my truck. I bought a set of energy suspension polyureathane (sp) bushings F&R. I got the rear on today and my steering is a WHOLE lot tighter. Not too hard to install either. (BIG HAMMER! lol) Took about and Hour to do the rear once we figured out what the hell we were doing.
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I say go with polyurethane, but only if you get greasable ones. Otherwise, poly squeaks too much.
    When I installed mine they slid right in without a hammer or press.
  6. tch777
    Jan 15, 2003
    244
    Yeah I know the polys slid right in. The press question was on the factory style rubber. But I did the pricing and I will be ordering the ORD greasables.
    Tim
  7. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    Get the press, upgrade to a bigger hydraulic cylinder if needed, I would use a grinder w cutoff wheels on the bolts. Only time I replaced bushings I replaced w Polyurethane and they dont squeak. They were cheap too. Urethane doesn't degrade like rubber. You are not greasing the actual bushing anyway, just the bolt and sleeve.
  8. sweetk30
    Nov 1, 2004
    25,538
    538
    you do grease the bushing. look at the ord ones :D
  9. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    thats what I thought too... until after about a year of use the bushing broke in half. I use normal all-poly non-greasable bushings now... no problems.
    j
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Eh, if you buy Energy Suspension non-greasables, they are the EXACT same bushings at ORD just without the little hole in the sleeve and you don't get a predrilled bolt(easy to do yourself if you have a lathe or access to one).
