leaf spring conversion kit ?
Discussion in 'The Garage' started by sweetk30, Mar 13, 2006.
  1. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    i have a customer at work with a newer coil sprung dodge 1 ton cummins. he wants to swap out that and go leafs . all of this to run 49" tires. any kits or info on how to do this would be great. we are basicly looking for a bolt on kit or semi bolt on kit and some welding and simple stuff. nothing to supper custom.
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Is he wanting to be hardcore, or just a mall crawler. If he's not really concerned with articulation, why not just a regular skyjacker 7" coil lift kit, and a 3" body lift. He could also put a spacer to get an extra 1 or 2" of lift from those front coils, and maybe a small block in the rear (although mine already has a factory block :eek1: ) If he did all of this and maybe trimmed the fenders and used some bushwackers, he would probably clear 49's, I would assume.
    I'm just curious what he's wanting to do with it? There is actually an air bag kit that gets some pretty high lift. I have never heard of a leaf spring conversion kit. I'm sure it could be fabricated, and maybe somebody has come up with a kit since the last time I researched it, but I personally don't know of one.
    thanks,
    James
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Well, since its a Cummins dodge on 49s, i'd have to guess the latter.
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Don't know of any kits, but a friend of mine put a HP60 in his Dodge, used the coil springs. He ordered almost 2' (yes feet) long coils from someplace in Cali, can't remember the specs, but he clears 44s with it. Basically took a donor front axle, cut the coil brackets and link stuff off, and put it on the 60. For a Dodge, looks good.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just wondering but why does he want to go leaves? just call up a spring company(alcan, deaver, national). have them make you some super arched springs to your sspecs then just make spring buckets and shackle mounts, shouldnt be too hard...
  6. sweetk30
    Nov 1, 2004
    25,538
    538
    first he has the 7" kit and 3" body in it now. it clears 40s just fine for what he does. he is wanting a big truck now. and as to making some stuff. he is a kind of picky and whinny customer. but if i can do it like i listed above it will be fine for him and me to make all of us happy.
  7. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    The air bag kit is made by kellerman air ride. Air ride techonologies here in Jasper make the controls, but Kellerman makes the lift kits. It goes from like 6 or 7 inch lift, up to 17 inches. Direct bolt in I am sure. Not cheap but they are awesome set ups. Thats how I would go if I had a mall cruiser.
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Thats what id do, prolly the easiest way. they did that on xtreme 4x4's first show
