Leaf Spring Cycling Write Up
Discussion in 'The Garage' started by Deuling, Apr 14, 2013.
  1. Deuling
    Deuling "Official CK5 Post Whore" Premium Member GMOTM Winner
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    I figured as this confused the H3ll out of me and could not find pics anywhere when i started researching, or a good detailed thread anywhere, that I would make a post, maybe make a tech article :dunno:
    For those that do not know, with long travel springs, this is how you get the most out of your travel and mount bumps, limit straps, and shocks accordingly, and also make sure stuff isn't going to hit. Also IMO the best way to get driveshaft lengths, and know how much you need to clearance drive shaft stops on the double cardan joints.
    Before shot, also before the diy4x flip in the rear.
    Started with 4" ORD custom springs with pins moved 1/2" forward that I was told had 6" of travel each way from ride height. 12" total travel. Also bought the HD shackle and bushing set from ORD that has the longer 4.5" shackles IIRC for the front springs.
    They really netted me 6" or so from where it sat before, but idk how droopy my stock springs were.
    Took my stock measurements from top of tube to the stock bump stop bracket and determined full droop and bump measurments from that by adding/subtracting 6" each way.
    Then took springs back out and made wood blocks that were the same height as all but the main leaf springs
    Then tore the springs apart. A big screwdriver pulled the military wraps out just enough to take the springs apart.
    Main leaf out
    Bolted the blocks in with steel shims my buddy made at work.
    Then bolted all up to the axle and took off the drag link.
    Full bump
    Almost full droop, still had another inch to go down
    I took measurments for my drive shaft so I can find out how long it needs to be and how much slip I need. Its going to use all of 6", so Ill try to find an 8" slip at least I think.
    Then I took the driveshaft out as the stops were preventing it to go down all the way at full droop, so I just ground off those little tabs you see on the ends, and it got plenty of angle and no problems. No pics of that, ill add later when I take the shaft back out.
    Took spring back out and put all back together with longer pins to account for the shim, then ground the extra of the pin off later.
    All back together.
    Heres a comparison.
    I also marked my spring plates where the center of the stock bump bracket would be so I know where to mount my Air bumps on the frame :thumb:
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    22,412
    614
    Kzoo, Mi
    Adam, what is your front shackle angle at ride height?
  3. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    Its angled back, it appears to be a good angle. Didnt measure though. I can get a pic next time im up.
    You can see it in the 4th pic, and the 2nd to last pic
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,866
    37
    Shackle angle is completely misunderstood based on the information available on the forums.
    Angle on the shackle, like most consider "good", actually makes the effective rate of the spring stiffer, at least on the kind of springs we deal with. It looks like it gives them tons of droop, but actually makes them stiffer in compression.
    We take that in to account when we design our springs, we design them as long as possible to fit with the stock mounts and set the shackle angle so the springs don't invert at full droop.
  5. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    Good deal chris. As long as you think its all good im fine with that.
    Did I do the cycling right in your book???
  6. 1977k5
    May 26, 2003
    9,866
    37
    Looks good to me.
    Unlike most springs, these will settle a bit. Because the rate is so soft and there are so many leaves, the friction between the leaves is pretty relevant. When you go out and use them, the pads will remove the paint and polish the leaves and everything will move more freely.
  7. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    So in my mind chris, after they settle, say an inch or so, I will have 5" of up, and 7" of down? As I dont really want to have to have another driveshaft made to make up for needing to change it down the line, I have a feeling this one will be pricy enough already :haha:
  8. 1977k5
    May 26, 2003
    9,866
    37
    The springs themselves can travel 14" easy, but we draw the line at 11" because that leaves a factor of safety before the steel yields and hence, the springs are actually soft and still durable. They're your springs, so you can do what you want with them, but that's the recommendation.
    You may want to give Stephen a call this week to verify everything, he's the one that designs our custom springs.
  9. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    Yah I plan to set it all up for 11", but want the capability of 12" down the road, and the reason whyI cycled and clearanced and took measurments at 12", so that I can still do that later without screwing anything up. And gives a nice cushion just in case.
  10. livid4dirt
    livid4dirt 1/2 ton status Premium Member
    Dec 4, 2005
    1,306
    15
    Warden, Washington
    Good info, this will be helpful for a lot of people:waytogo:
  11. Fred_M1010
    Fred_M1010 1/2 ton status Premium Member
    Apr 22, 2009
    744
    Sweden
    That's only true if the shackle is so short that the spring bottoms out and can't extend any further.
    And I can see how that can be a problem with lift springs with a big arch.
    But as long as it can't bottom out (longer shackles or less arched springs), the spring gets progressively softer on compression with more shackle angle.
    I'm not saying that it's a good thing for street driving though...
  12. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    Thanks bud. That's what I was going for. I was so confused for a while on why you do this and how exactly. And not much really good info anywhere with pics.
  13. mrk5
    Apr 20, 2004
    11,487
    282
    Northern Colorado
    When I was looking at my shackle setup also with a set of ORD springs like Deuling, I found this information enlightening:
    Taken from here: http://www.afcoracing.com/tech_questions_leafsprings.html#shackles
  14. charity case
    charity case 1/2 ton status Premium Member
    Aug 19, 2010
    159
    119
    rancho cucamonga ca
    in that full droop pick with all the crap hanging off it.... i hope you strap it well before that. it looks like the shackle is straight inline with the spring.
    id be curious in the actual vertical wheel travel bumped and strapped?
    any steering clearence issues yet? im getting ready for crossover steering and wondering
  15. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    I plan on limit straps. But Idk if I need them with how hard it was to pull the sprigs down the last inch of travel.
    And I don't have crossover yet, so Idk if it will get messed up or not. Guess ill have to find out
  16. 454Sub
    454Sub 5/8 ton status
    Apr 11, 2012
    1,872
    72
    Southern Illinois
    12in travel, you will need crossover no questions asked. Even rinky dink no movement 12in springs need crossover, you certainly will.
  17. Fred_M1010
    Apr 22, 2009
    744
    Sweden
    I agree with this:
    But the only thing that would make the spring stiffer with a smaller shackle angle (other than if it's bottoming out)
    would be if the rotational friction of the shackle bushings would be very high
    (as the shackle would need to rotate more for a certain amount of wheel travel), and/or if the shackles are very short.
    And maybe that is the case in racing...(like the Afco document seems to relate to)
    But I can't see how that is applicable in offroading...
    We usually use longer shackles and poly-bushing with very low friction.
    So that force will be negligible in comparison with the jacking effect described above.
  18. Deuling
    Dec 8, 2010
    23,113
    1,421
    Muskegon Michigan
    I think I confused you. I don't have crossover yet but I will be getting it. Just don't have $500 at the moment
  19. 72blazerguy
    72blazerguy 3/4 ton status Premium Member
    Aug 6, 2007
    678
    fairbanks, ak
    You will be very happy when you get it. It SUCKS to have flexible suspension w/o crossover. As soon as that drivers side tire drops, no steering. I wheeled without crossover for years and was always having to compensate.
    Nice writeup.
  20. pblaze725
    pblaze725 build bash rebuild Premium Member GMOTM Winner
    May 28, 2007
    4,043
    144
    Dallas
    Customz fab up some homebrew cross-over on the cheap.
    Mine has been working awesome :D
