Leaf spring hangers and removing body from frame
Discussion in 'The Garage' started by Pvt. Maggot, Nov 5, 2006.
  1. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    So, on my new blazer frame, the people were going to scrap it..so they cut the mounts insted of unbolting the leaf springs, so do you think i'd be better off taking the leaf spring mounts from my old frame, or buying new, or making new ones? I'd like to use the old ones if I could, to keep costs down as much as possible..but I don't see how I could take them off without messing them up pretty bad hah..any help would be great. Also, when they dropped it off they drug it off the trailor being that it has nothing under it..I have it blocked up on the frame now, what would be my best bet for getting the body off? looking for suggestions from people who have done it, thanks alot guys!
    Jack
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    get new brackets from a junk yard. If its the rears, and you are going to lift it, you could just get a shackle flip bracket to start wtih.
    If keepign stock height, just get them at a yard.
  3. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    I have 4' leafs all around for it, And I have another blazer that I can take the mounts from. So i'm guessing that would be my best bet, any info on how to take them off without messing them up?
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    where I can get to I use a grinder on the rivets. on the front mount under the rad support you can use a drill, it takes longer. you don't need to go all the way through. just drill the head off and hit the mount off with a BFH. then grind off the rest of the rivet and punch it out of the frame.
    when it comes to the body get lots of friends. Get everything disconnected in the way of wirring and body mounts. remove everything heavy from inside. Do you plan on keeping it? If not simply cut it up.
    If you are keeping it then either pick it off or roll the frame out from under. whichever is easier for you. know anybody with a forklift or backhoe that likes free beer?
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    also use 7/16 bolts to reinstall. and if possible get them with a smooth shank with in the middle before the threads start. thay fit better in the holes over 3/8 and that flat section gives you much better suport over just threads.
  6. gmcburb1965
    gmcburb1965 clever user title
    Oct 29, 2005
    61
    Colorado Springs
    If you have another blazer with good mounts why not just swap the body over to the good frame?
  7. Pvt. Maggot
    Sep 27, 2005
    559
    Brownsville PA
    The blazer I bought have a good frame and body, my other blazer has a bad body and frame, i'm taking my engine and a front clip, and a few other parts from it, and thats it.
  8. goldwing2000
    goldwing2000 Guest
    I've always found that a torch is the best way to get rid of rivets.
    Second best is an angle grinder. Grind off the heads, then just punch them through.
