leaf spring, lift, and shackle flip ?'s
Discussion in 'The Garage' started by bad_bo_ti, Feb 20, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    leaf spring, lift, and shackle flip ?\'s
    ok heres the deal, i am adding a 2in zero rate to the front and probably maybe a longer shackle up front, so thats about 3in extra, i have 6in prearched springs front and rear so that is 9 up front. is there a way to take off the rear 6in springs and put in stock leaf springs and do a shackle flip with an extended shackle to get 9in? would it ride/ flex alright? my lift i have is a tuff country ez ride lift what other options could i go with out putting in an actual block in the rear? how much lift can i get out of different shackle flips? thanks chris
  2. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Re: leaf spring, lift, and shackle flip ?\'s
    you could keep your 6'' rear springs and put on a 2 1/2'' shackle flip and call it close enough. Or if you are a little saggy in the rear you could keep the 6'' rear springs and use a 4'' flip /forums/images/graemlins/tongue.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Where are you getting this 2" zero rate?
    I can see using a 1" in the front (I would never do it on my own truck) but 2"? Even though it is bolted to the spring pack I still don't like it.
    Not trying to step on any toes....just trying to look out for ya.
  4. bad_bo_ti
    1,027
    OhiO
    i am making my own, drilling out leaf springs so i can use bigger center pins
