leaf spring options
Discussion in 'The Garage' started by guz71, Dec 8, 2006.
  1. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    Im bout to dive into my truck head first here next week finally. While im swapping axles, i want address my problem with the 5.5 inch lift blocks that came in the rear. With the bigger D60 and zero rates up front, it will be about 7.5 inches of lift. So in the back, should i run something like 8 inch lift leaf springs or 6 inchers and a 2 inch block? Im thinking that with the 8 inch springs, im going to loose all of my flex?
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    run a 4 inch shackle flip in the rear. then maybe some longer shackles. a zero rate and some 2-3" lift springs. that will ride nice and flex good.
    I had 8" rear springs. they do not flex at all.
  3. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I run 6" skyjacker softrides and 2" blocks in the rear and its stiffer than i would care for it to be.
  4. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    This is your best setup for a soft flexy ride.
