Leaf spring pin help needed
Discussion in 'The Garage' started by 8_YOUR_H2, Aug 29, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I broke one of my leaf spring spring pins and the only replacements have pins that are bigger than the stock ones. They are 3/8" threads just fatter heads. Would I be ok grinding them down so they fit. Now I am sure they wont be perfectly round but I would get them as close as I can. Or should I drill out the spring perches? Any tips?
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    chuck one up onto a drill motor and drag it up and down a file until it fits. That ought to be pretty much round.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah I ground mine down slightly to fit into my ff14b perches. Just do lots of test fitting so you dont grind any more than is absolutely necessary...
    J
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I don't see why it wouldn't work. Just an FYI Rancho makes some that fit. I know because I had to buy some- the one that come w/ the ORD zero rates didn't fit my front axle. Same problem you had.
  5. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Actually NAPA had the correct pin. $4!!! WTF!!!
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    drill the axle
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    FWP has the Ranchos for $4 a pair.
