Leaf Spring Question
Discussion in 'The Garage' started by k5baby, Nov 14, 2005.
  1. k5baby
    k5baby Registered Member
    Jun 7, 2004
    62
    Prattville, Alabama
    What is this and what causes it? How do you fix it?
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    combo of center pin loose and ubolts not tight . comon on old rigs. take i big hammer and hit it back and see if it moves again if so get new center pin and ubolts .
  3. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Having your overload spring shift like that is common. I think it's caused by the contact surface between the spring and spring perch not being clean as well as the Ubolts not having proper clamp load due to low torque on the nuts. Those blocks aren't helping things, either. Knock your overloads back straight and if you have 5/8 Ubolts torque them to about 225 ft/lbs. If you have 9/16 Ubolts, back off to about 190.
  4. k5baby
    Jun 7, 2004
    62
    Prattville, Alabama
    Thanks, I will give that a try. :bow:
