leaf spring question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Nov 19, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    so im installing my leaf springs when i noticed that one of the bushings for the front leaf spring has no metal cylinder in it, i went ahead and bolted it up just for the helluvit, however is this little metal cylinder really necessary?
    phill
  2. dyeager535
    26,978
    I would *guess* (since no one else answered) that yes, its there because its usually there because its necessary.
    Probably allows you to compress the shackle until it hits that "sleeve" which keeps the bolt from "wiggling" as much, which will elongate the bolt hole. Dads 3/4 ton did that, I guess I should check to see if the "sleeve" is missing.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yeah, sounds right. Without the sleeve in the back (shackles), you would tighten up hard on the bushing and it wouldn't move right. On the front, I don't think you would pinch the bushing but the bolt would wallow out the bushing.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
