LEAF SPRING RATES
Discussion in 'The Garage' started by TONYP, Aug 13, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    Just got off the phone with Macsprings comp. and got the info on my new leaf springs...
    stock springs (72) 540lbs. 3 springs no lift...
    new springs 800lbs. 7 springs 6"inch lift...
    right now I have 4" lift and not sure if its the stock leaf just flipped and a 2" block to get to 4" inch, so not sure what the lbs. is but it is a little stiff up front. the mac guy told me if I remove the 2nd leaf it will drop the lbs to 610 lbs...what are you guys running on lbs.? /forums/images/graemlins/thumb.gif
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Make and Model
    Suspension Manufacturer
    Spring Rate (Lbs/In)
    Number of Leaves
    Free Arch
    73-91 Blazer/Jimmy
    Pro Comp (11411) 520 5 3.72
    Rancho Suspension (RS86206) 520 5 3.72
    Rough Country (8002) 604 5 3.48
    Skyjacker (C140S) 490 5 5.00
    Superlift "H.D." (01-234) 605 6 4.125
    Superlift "Superride" (01-234-6) 560 5 4.375
    Tuff Country "H.D." (TCI-C4HD) 395 4 4.75
    Tuff Country "EZ-Ride" (TCI-C4M) 295 3 5.75
    Warn "standard" (721013) 672 5 4.75
    Warn "E-Z Ride" (721014) 490 2 5.00
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    about 1/3rd of that. ouch.
  4. TONYP
    Aug 13, 2002
    2,116
    so cal
    Make and Model= <font color="blue"> 72 K5 </font>
    Suspension Manufacturer= <font color="blue"> McCallster Spring(they make the leafs for most major guys...fabtec, Ranco etc.)...</font>
    Spring Rate (Lbs/In)= <font color="blue">800lbs-remove number 2 leaf so there is only 6= 610lbs... </font>
    Number of Leaves= <font color="blue">7 </font>
    Free Arch= <font color="blue">need to check but lift is 6"inch </font>
  5. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    So they make lift springs for Dump trucks? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    I thought my Rancho's were stiff...
    Rene
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    My Alcan's are 260lbs in the front and 220lbs in the rear.
  7. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Those sound stiff as hell Tony. I'm running the Tuff Country EZ rides with 295 lbs/in spring rate. I like them pretty much, they seem to be nice and soft and somewhat flexy.
  8. TONYP
    Aug 13, 2002
    2,116
    so cal
    the stock springs with reversed arch are 540 lbs. remember the first gens are shorter then the second gen leaf pack..so I think most front springs will be rated higher... /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. TONYP
    Aug 13, 2002
    2,116
    so cal
    just checked Tuff Country...
    72 K5 6" lift 495lbs.
    73 and up 6" lift 495lbs. 4"lift is 325lbs.
  10. TONYP
    Aug 13, 2002
    2,116
    so cal
    need more info.... /forums/images/graemlins/thumb.gif
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The reason that GM made our trucks with stiffer springs is because there was no sway bar up front. I don't know that I would want to drive a truck with sub-300 lb/in springs in the front and now sway-bar.
    My rancho springs in the front are 720 lb/in. My stock rear springs are about 225 lb/in. It makes the truck handle like crap because the back end will move and the front won't.
    From the factory all trucks are built with more roll stiffness in the front than the rear. Because the front springs are more inboard than the rear they would have to be stiffer than the rear to even have the same roll stiffness as the rear. When they put in the sway-bar they also softened up the springs to make it ride better and also handle the turns.
    If I was you I would go the same path the General went. Swap in a sway-bar. Than toss in a spring in the 300-400 lb/in range.
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
    thats the answer I was looking for...everywhere I looked the 72 truck leafs were stiffer, and the no sway bar is why...heres a pic of the stiffer leafs and they seem to work...now the back need help and I have 57's ready to go on...
  13. GreyZuk
    GreyZuk Registered Member
    Jun 8, 2013
    23
    Fresno, CA
    sorry if i'm dredging up a dead post, but I have a set of 4" lift, 2.5" wide, 6 leaf, .25" thick main leaf, 48" long springs for the front of my Blazer, They only had a faded "made in Japan" on the springs, but when I run the numbers I get 180lb spring rate springs which sounds way way low than the 300-500 rate that others are posting.... Am I doing something wrong? I weigh 180 and when I stand on them they definitely dont droop noticeably
  14. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    How are you calculating the rate?
    Spring rate numbers from lift kit companies are totally random and I wouldn't trust them at all, there is no convention for how (or if) it's measured.
    The first inch of compression from free arch takes less weight than an inch of compression at ride height and less still than it will at full compression, leaf springs have a progressive spring rate so where you measure it matters a lot.
  15. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    From a CK5 post back in 2008:
    Some more math..........
    From one of the Excel spreadsheets on Pirate (by Triaged):
    R = ((2+(N'/N))*(E)*N*W*(T^3))/(6*(L/2)^3)
    R = Rate (lbs/in)
    N = number of leaves
    N' = number of full length leaves (usually 1)
    E = Modulus of Elasticity in Tension (about 30,000,000psi for most steels)
    T = Thickness of one leaf
    L = Length of the main leaf
    Using that equation and my 52" spring gives a rate of 234.2 lbs/in
    It looks like the other equation on Pirate boils down to the same thing.
    -G
  16. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Here's another one. What a surprise....I created a spreadsheet for something K5 related!!! :D
    -G
  17. GreyZuk
    Jun 8, 2013
    23
    Fresno, CA
    Greg, my springs fall perfectly on your scale
    .250 main spring
    This could be what is throwing me, I'm eyeballing the springs with a cheap tape measure, not a calibrated micrometer. They could be closer to .300
    2.500" width
    48" long
    6 leafs in pack with tapered end cuts.
    177lb
  18. Doppler
    Doppler 1 ton status
    Jan 6, 2011
    27
    ventura, ca
    That's a nice scale...but what about a 3 leaf pack? Aren't a lot of front springs 3 leaf?
