Leaf springs, any size, length, and rate, what would you choose?
Discussion in 'The Garage' started by 84_Chevy_K10, Aug 19, 2004.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ok, imagine you're the owner of a huge spring company or something and can make springs for your trail rig. Any length, any spring rate, etc.
    What would you choose? Why? How long? What spring rate? Where would you put the centering pin?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the only limit in the front is your front mount. anything longer then a 56" up front and you end up losing approach angle. unless you have an offset center pin. In the rear the longer the better as long as you can control them.
    rates
    front 300-250 rear 200-250
    ALOT of thin leaves is where it's at.
    and for the centering pin, they didn't name them wrong. the closest to the center they are, the better your pinion will travel.
    also it doesn't matter how soft you make or how much travel you have built into the springs. If the shackle can't get them to do thier thing then it's no use.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Well actually for me that's not totally true. I can do the 56s up front, great, no problem, that's what I've got planned.
    There rears I cannot really move my front mount forward all that much because the gas tank is in the way. I really wanted to do 63s in back but I dont have time to move my gas tank right now so, I might not be doing that.
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    im a real big fan of my 63's just wish there was more lift with the same spring rate.... /forums/images/graemlins/smirk.gif
    3 leaves and a flipped overload, i may re-flip the overload and see if i can do away with the 2" blocks i made.
    pull the 8 or so bolts outa the bed and drop in a blazer gas tank, then the front mounts can be moved forward to make a bit o room
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A Blazer tank makes for crappy departure angle.
    If anything I'll put a fuel cell in it, but that is well into the future.
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    [/ QUOTE ] Disagree there. My is a long bed and I have a 40 gallon tank back there. I haven't hit it yet. The only way I see is if you came down straight off a 3 foot ledge.
  7. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    Doesn't the tank sit up in the framerails anyway?
  8. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    The twisty curly kind that wrap around shocks in a 250/lb per inch rate.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, I know, STFU already /forums/images/graemlins/rolleyes.gif
    I really do want to link this thing though, it make little/no sense to go through all this pondering to keep the leaf springs, but I suppose for the budget 'wheeler you can't beat it.
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    why not look into inboarding a set of 63's? thats what NORULEs used on his ford IIRC.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    hmm.......
  12. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    I guess we're putting them in different spots, because if i get hung up on the gas tank, then the 14 bolt was stolen /forums/images/graemlins/whistling.gif
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    The 14 bolt is 4 feet forward of the rear bumper and tank.
    I just went out and looked at it, maybe I'll put the tank in the bed and be done with it. /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  14. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    i had room over the axle. its no good for getting airborn. but they havent hit yet. just food for thought
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That is correct and it flexes like mad...
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Mine is pretty much the same. I actually built a cross member and bump stop to keep the diff out of the tank. But my 23? gallon tank doesn't even have a skid and it's got one small dent in it in 2+ years of being back there. A rock has to come up just right to get in there without the tires or something else keeping it out...
  17. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Can you explain that set-up to me? /forums/images/graemlins/confused.gif
  18. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Steve-
    Instead pf the springs being out on the outside of the frame rails you have the mounts under the frame like the older trucks and jeep ran em. flatter leaf packs and gain lift. In this manner the springs will have tons of movement cause of them being mounted closer together. You gain leverage at the tires to help creat axle flex. Be ready to get the shocks out as far as you can to control it though.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'm wondering what a set of 14" travel 5150s and a set of 63s, inboarded so that hte front was damn near under the cab would be like. I can use ford towers in the rear to mount the 5150s straight up and down and combined with the agressive valving I think I'll be able to control them.
    I'll leave the overload on to control the wrap.
  20. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Jeremy, is there any pictures so I can clarify what it looks like (I have a picture in my mind, not sure if it's correct or not though) Thanks for the explanation! /forums/images/graemlins/peace.gif
