leaf springs bolts, how tight?
Discussion in 'The Garage' started by muddybuddy, Jun 8, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, how much do the i-bolts for the leaf springshave to be torqued?
    thanks
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    U-Bolts???? T-I-G-H-T
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    YA, I use my BEEFY Impact wrench to take off and install leaf spring U-bolts. I once had one loosen up. It angled back put tire into rear of fender opening, and shaved off the leaf pack pin. Thats a job to replace that pin with a bolt and grind it down to fit in the little hole in the axle. So yeah go TIGHT on those bolts. Lock washers and nylon lock nuts for sure!!
    :cool1:
  4. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    140lbs
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks for the replies.
    im actually talking bout the bolts that connect the leafs to the frame. any specific amount, or just as tight as i can get it socket style?
    thanks
  6. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    110lb for the spring eye bolt to the frame and the one for the shackle
  7. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Again I used the impact wrench!!! :grin: :grin: :grin:
  8. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    110 for the spring eye bolts? holy crap... I use locking nuts and probably put about 30 ft/lbs on them... is that 110 number an actual spec from a real source? sounds more like a u-bolt spec to me...
    j
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    opps miss read your post 140lbs for ubolts. I ussually tighten the leaf springs bolts between 35-45 lbs.
  10. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    That just had that happen to me, had to fix it on the trail. I'll be putting the impact on those things after I get one.
  11. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    Ya its fun trying to compress your leaf springs back together using a C-clamp and putting a new bolt and nut through center hole, and then grinding it to fit the hole in your axle. But my CV driveshaft with 1350 U-joints held up to the axle being way outta whack. And its a good thing local law requires I have mud flaps or the fender would have torn up my tire and that wouldnt have been pretty while cruisin' down the highway!! :eek: :yikes:
  12. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    That's more like it, 110# would crush the hanger into the bushing badly and create a very stiff ride. ;)
  13. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    Tighter than this...
  14. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    110 lb is right out of the manual for a 1980 k20 just replying what the book says
