leaf springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cooker, Dec 22, 2001.
  1. cooker
    cooker Registered Member
    Dec 11, 2001
    22
    north carolina
    rear springs sagging and need to replace them will a 2 inch lift require any changes or should i replace with stock height who should i buy them from this is for a 88 k5 thanx for the help
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you want to put in new springs you might as well lift it.
    Check out <a target="_blank" href=http://rough.roughcountry.com/>Rough Country Suspention.</a>
    They have some reasonablely priced 2" lift kits.
    If you just want to get rid of the "saggy butt" You can install some add-a leafs. installing them fornt and rear will also lift your truck 1"-2" The long leafs ride better than the short ones
    rough country sells them also
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
