leaf springs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RATAH, Nov 12, 2002.
  1. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    Hello
    how many spring are there on a stock 85 blazer?
    mine has 6 in the rear
    and 3 in the front
    no blocks
    just wondering
  2. dyeager535
    26,977
    2/5 or 3/6 optional for the most part.
    You could probably get a 2/6 and 3/5 as well, but I don't recall ever seeing that on a truck I knew was stock. (although the CUCV's may have 3/5 for the diesel weight IIRC)
    I've never seen any factory literature stating exactly what was available what years, unlike earlier manuals that did show how many different springs were available.
  3. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    another ?
    the sticker in the glove box says rear axle 3.08
    it had a 700r4 and a 208tase
    i switched to a 350 205tcase
    is that gear ok with the 350 and 205
    also says tire size 31.5x10.5x15
    thats whats on it now
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You should be fine with your gearing as long as you don't go bigger than 31".
    I did have 32" with the 350/205 and it felt sluggish, but the 350 can take it. not the 700 though.
  5. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    thanks
    what would be better than the 3.08?
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    honestly? anything!
    I need to kinda guage where you are headed with the rig. i think 3.73 a decent for 35" but as soon as you go 38+ your gonna need 4.88's or higher.
    I am running 4.10's and 39.5's and on steep grades and hills it is a joke.
  7. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    well id like to get 35's in a few months
    and a 2in lift
    dont wanna go to high as this is a daily driver
    and i pull my boat about 4 times a week to the lake
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i know nothing about towing. my guess would be to have 4.10's so that you have the pulling power and so that you do not roast the tranny.
  9. dyeager535
    26,977
    ACTUALLY....the 700 is a better choice without changing the gears for 1st gear only. (lower than the 350) However, 700's don't like being lugged, which is what would happen with larger tires. I had 3.08's and 31's with a 700, it was ok city driving, but OD was pretty useless under 60MPH on anything but flat ground.
    Personally, if you don't wheel, and stick with 33" tires, 3.42's seem to be very close to perfect. That is if you don't like to race. Daily driver/towing is still kind of a rough combination, (and 3.42's won't be ideal) the 700 would be better suited for BOTH uses, just because you could use steeper rear gears and cruise ok, but the TH350 tends to be stronger "stock".
    Don't have much answer for you, just have to decide where you want to compromise...mileage, engine wear/speed, acceleration, towing power, height, etc. and take it from there.
    If its only for show, personally, I don't like lifts. If I was towing as often as you, I don't think I'd go for a lift either, especially when you can usually fit 33's with no mods. Thats just personal opinion though.
  10. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    Thanks zakk and Dorian
    i would like to do some wheeling but
    not the hardcore kind you guys do /forums/images/graemlins/smile.gif
    what ever i decide should the front be geared the same?
    sorry for all the newbie ?'s but iam new to this
    and wanna learn
    Thanks again guys
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    yes, the gearing must be nearly identical or you will nuke your t-case.
    Examples:
    4.09 & 4.11 are OK
    3.08 & 3.42 is not
  12. dyeager535
    26,977
    I definitely don't hard core wheel lol.
    I've got too much time and money into my truck and its body to take it out and put dents in it having fun. Scratches are ok, dents are out. /forums/images/graemlins/smile.gif
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i only wheel the 3" and smaller curbs. any more and my brakelines will snap /forums/images/graemlins/smirk.gif
  14. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Ratah
    If you want to put 35" tires with 2" of lift, you will have the same setup I have now.
    Just to drive it on the street I had to cut 4" of the fenders in front of and behind the fron tire for turning.
    When I went off road I had to take the same from the top. and a couple of inches on the rear fnder.
    So expect a lot of trimming.
    As for the gearing, if towing and a litle off road is your game then low gearing will be nice so 4.56 or 4.11
    If you will be driving it daily and some occasionnal towing or off road, then 3.73 would be good, if you keep the 350.
    With if you want to go back to the 700 then 4.11 is a minimum in my opinion.
    33" cleared perfectly with the 2"lift, and only rubbed slightly when I went off road in extreme places, so if you don't want to cut it, go with 33" and 3.42 or 3.73/4.11 for the above reasons.
  15. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    anyone know where i can price the gears
    maybe a website
    Thankyou all for your time
    I love this website /forums/images/graemlins/thumb.gif
  16. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would recommend Randy's ring & pinion
    But then you need someone to install them.
    There are others, but I think these are the best I've seen for the best price.
  17. RATAH
    Aug 10, 2002
    576
    Franklin,Ohio
    I think a guy i work with can help me do it
    we work at Chrysler plant in dayton
    and he is a machine repairman,,
    oh BTW i dont own a Chrysler product,
    im a Chevy man
    i get doged at work when i wear my Chevy Truck hat /forums/images/graemlins/smile.gif
    but they can kiss my azzzzzzzzzz !!!
  18. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    I run 4.88s with 35s and a 700, in OD I can keep up on the SoCal freeways with out to much RPM.
