Leak diagnosis
Discussion in 'The Garage' started by dremu, Oct 15, 2006.
  1. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    So my K5 is emitting fluid fairly prodigiously.
    The tow rig is also doing so, but it needs a new motor, so that's a simple, if expensive, fix. I do not have the emotional nor financial sitch to do that to both trucks though =))
    The K5, actually, seems to be mostly leaking ATF, though there's also some brown crap down there as well. It drips onto the ground, so I see it on the driveway, but there's ATF (i.e. red) around the cover to the (err, flexplate, right, 'cuz it's a slushbox?)
    So, the question is, how do I figure out what's actually leaking? Soak the whole thing in engine-brite, wash it off, then park over fresh newspaper or something and wait a day?
    I replaced the tranny a while ago, and IIRC the old one leaked just as much ... is there a seal around the shaft that goes into the torque converter, maybe I should go after that? Eww. Pulling a TH350/203/205 is not fun (plus some redheaded idiot has three crossmembers on there =))
    Any input welcome.
    -- A
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    For one thing , I would check the pan bolts . I kept thinking my front output was leaking , and looking under there this weekend I notice one bolt just plain GONE , the rest were not too tight . So from now on I have to remember to torque these as well after a filter change and a little driving .
  3. dremu
    Feb 27, 2000
    15,958
    452
    Checked. Replaced gasket and filter while I was down there. Still bad. (But thanks!)
    Keep 'em coming guys.
    -- A
  4. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    there is a seal around your input shaft that the torque converter seals on. very like ly that one.
  5. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    sounds like a pump housing leak to me, common problem depends on how long it has been since it was rebuilt
  6. dremu
    Feb 27, 2000
    15,958
    452
    Makes sense. Thanks!
    -- A
  7. dremu
    Feb 27, 2000
    15,958
    452
    What pump? On the tranny? Where on a TH350 would I find one of these? [Is that like "Where on the ox do I find the Oxnard?"]
    -- A
  8. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    The torque converter is "plugged" into the front pump on the trans. That's where.
  9. dremu
    Feb 27, 2000
    15,958
    452
    So is there a seal there, or what do I do to fix it?
    -- A
  10. Slapperbar
    Nov 29, 2005
    2,747
    3
    I think the pump seal goes betwixt the pump and trans body.
  11. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    The pump body is the perfectly round iron thing, the input seal is the little round blue seal near the input shaft. this is a 400 I have in the garage, but a 350 isn't really any different
  12. dremu
    Feb 27, 2000
    15,958
    452
    Sweet. A pic IS worth a thousand words.
    I think droping the tranny and replacing the input and pump seals is in order. Anything else I should look at whilst I'm there -- I hate to drop that mess twice (Doubler, aargh HEAVY!)
    -- A
  13. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you do not have to drop the tranny all the way to do this, if you really don't want to drop the tranny replace the belhousing bolts with some long bolts and slid the whole thing back, all you have to do is get enough clearence to remove the torque converter and replace the seal then, its also a good time to replace the rear main seal of the engine if needed, but first make sure that it is that seal, the kick down cable seal and the dipstick seal also can leak and they are both in the front of the tranny
  14. dremu
    Feb 27, 2000
    15,958
    452
    Problem with the Doubler is that I gotta sorta drop it to sneak it back as it's TIGHT in there ... I'm trying to avoid a body lift 'cuz I'm lazy.
    ::shrug::
    JMS, good call on the starch powder. Thanks!
    -- A
  15. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Do you mean GINGER?
    :haha: :haha: :haha: :haha: :pimp: :rotfl: :rotfl: :rotfl: :rotfl: :haha: :haha:
  16. dremu
    Feb 27, 2000
    15,958
    452
    Eh? As in Maryann?
    In any event, I was referring to the author of the post and the owner of the truck, i.e. me.
    -- A
  17. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    that pump housing is fairly easy to fix just like you said its a pain in the butt for ur doubler to be dropped down but it has to be done my friend only way UNLESS u really wanna pull the engine to get at it haha
  18. dremu
    Feb 27, 2000
    15,958
    452
    Bah. Don't remind me -- I gotta pull the 454 outta my OTHER truck ... but it's 2WD, so that's something...
    -- A
  19. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Its ok...
    I'm a GINGER too. :D
