Leak in Engine Block
Discussion in 'The Garage' started by tsquared275, Mar 19, 2006.
  1. tsquared275
    tsquared275 Registered Member
    Jun 28, 2005
    13
    Plano, Texas
    This morning, I started up my Blazer, and I noticed some smoke coming from my engine bay. So I killed the enigine, popped the hood, and noticed some radiator fluid coming out of the passenger side of the engine block at a steady stream. I believe this is a freeze plug, or somthing like it, but I just wanted to double check, and if anyone has some sort of diagram of a 350 engine block, that would be great! Thanks for any help!
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Could be a couple of things. Loose hose clamp on the lower water pump port, a leaky water pump gasket or hose, could be the freeze plug. You really need to get under the vehicle and find the leak first. Dont want to do the repair job twice.
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    At the front of the engine? More than likely it's a water pump gasket like 88silverado said.
    Thats a much more common/likely culprit than a freeze plug.
