Leak in the rear of my 700R4
Discussion in 'The Garage' started by bigburban383, Mar 9, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    I had this leak, thought it was the front pump seal so I replaced that. I was wrong it leaks like a sieve between the Transfer case and the Rear of the 700R4. What is this most likely? Is it that big o-ring that goes between the T-case and Tranny? Thanks /forums/images/graemlins/waytogo.gif
  2. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I would say its that big "o ring"
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i could be, check to see if there are any nicks or cracks, (i had one do that and it had a huge crack in it /forums/images/graemlins/yikes.gif)
    also make sure the bolts are tight /forums/images/graemlins/waytogo.gif
