leak under dash????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wraenking, May 24, 2003.
  1. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    well with the recent rainy days here in the north east, i discovered that water is dripping from behind the dash, down by the hood release, and soaking my floor. im sure some of you have seen this so any help or ideas would be appreciated. i want to nip this one in the bud ASAP.
    thanks
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    It's most likely the windshield gasket is leaking at the corners and needs to be resealed. Mine was leaking there too and resealing the gasket fixed it.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    and check heater box firewall seal also,
    at least its just water, ive got oil leaking down my firewall and soaking driver side floorboard and carpet, leaves a puddle on ground even, i dont care too much really, ill get around ot repairs one day, its too small of a problem right now to deal withheh
    good luck
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    so do i need a new seal? you said to reseal it. what do you do?
  5. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I had the same problem with a 79 Shortbox I had, turned out it was leaking in where the E-brake cable came into the cab. A little bit of silicone and it was good to go.
