Leak Under the Dash
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Nov 23, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Everytime it rains, there is a constant drip near the parking brake pedal assembly. It's not the windsheild gasket. Could it be coming through the cowl somewhere?? Thanks
    [​IMG]FUN WITH 31's![​IMG]
  2. Grim-Reaper
    7,385
    Atlanta
    More than likely it is the windshield gasket. It gets in the top and there is a gap and the water sits in the bottom and you pobably have a rust hold under the rubber at the bottom. It is possible that you have a rust hole in the box area under the cowel but the windsheild frame is more likely. The area under the cowel has a slope and it runs the water off through the fenders. If it is in the box area under the cowel you should be able to put a trouble light in the box area and see light under the dash.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I had the same problem but on both sides . I took my dash pad out and underneath the winshield gasket you could see streaks down to the kick panels . Also the caulking on the gutters was gone that fixed another set of leaks .
