Leaking 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Shawn, Jun 28, 2000.
  1. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Ever since I got my used 14 bolt (4 years ago), it leaked just a little around the right axle tube (where it meets the pumpkin). It only leaks maybe 2 drops per week so it was never a must to fix it. The axle is in great shape except for that. I was told to weld the seam would be a no-no. Is there another solution for this?
    Shawn
    87 K5
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    I think it is time for you to upgrade to a GMC 2-1/2 ton military axle, why take any chances!!!
    Steve
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I'm not an expert in rears(or anything for that matter), but I have a suggestion, I had a full floater in my suburban, try RTV blue around the tube. This stuff works real well. And if you don't think thats strong enough stuff try a little Jb weld, that stuff works well also. hope this helps
  4. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I was going to say the same thing, I bet that a little RTV will work. If not I used some stuff called Liquid Steel and that seemed to work real well too.. good luck
    BlazerBoy
    http://generalblueballs.coloradok5.com
